Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1491871 times) previous topic - next topic
Reply #3030
Quote from: daminc;364085
a little more done, and even closer to the finish....
installed rad hoses, throttle cable cruise cable, HORNS........ hood release, trans cooler, misc other small ticket items....
are these for anything important?
I assume this is for the light under the hood
That first one is for the digital temp sensor. I looked on mine today. When I get home from work tonight I'll pull the ignition coil cover off and see if that plug is on my T-bird. My car has every option but the sunroof so if it goes to something it'll be plugged in on my car.
Reply #3031
awesome, thanks
Reply #3032
I'm 95% certain that mystery plug by the coil is for the low oil level sensor.
Reply #3033
I'm looking it up in the book now...
Reply #3034
well, I just went through the entire evtm...I can't find ANYTHING that plugs into ANY 3 terminal connector in that location of the car.. the low oil sensor has only 2 wires according to the book, and the relay is behind the dash
Reply #3035
Vinnie... you still got that low oil sensor around that you pulled out? if you do, what does the plug look like
Reply #3036
todays progress.... Plugs in, AOD lines on..... Fan on (temporarily)
AOD bolted to X-member... AOD x-member bolted down
I think I'm down to computer, extending the O2 sensor wires, and I have to move the shifter to the center of the console now....and toss the battery in, and wire the starter...... not all in that order...lol
Reply #3037
Jerry, I'm surprised you didn't flip the tranny cooler the other way and route the hoses down the passenger side. Glad to see you're down to just a few things. Man, I wish I was there.
Reply #3038
actually...I was looking there and there was more room on the drivers side to get it past everything .. so that's where it went...yep a few things left.... I'll try to do them during the week after work. Hated to have to put the old fan on, but it's temp....and no I don't have a shroud for it...lol I will be careful
Reply #3039
I'm proud for you. It's been a looooong road you and the Cougar have traveled.
Reply #3040
Many miles, and it's only moved 10 feet in 2 1/2 years
Reply #3041
That'll change soon enough.LOL.
Reply #3042
Almost there, almost there!
Reply #3043
OK, had to take care of some stuff the last couple of weeks..... back to the car this weekend....
Reply #3044
Hey, after all this time, what's a few more days? Nothing to it.
I'm hoping to get some Sport time next week. Got a little today, but I want more.
