Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1492721 times) previous topic - next topic
Reply #3000
Just realized I'm on page 300.........I'll try to finish the project on page 302
Reply #3001
QUOTE=daminc;363971]I do feel a little bad about removing the cross member thingy...it's one of the few pieces of metal on my car that actually survived from day 1[/QUOTE]
That's going to cost you 0.1 seconds in the corners. Car is now junk. (j/k)  ;);)
Your work is amazing, car looks great.
But we all know black Cougars are the quickest!  :popcorn::popcorn:
Reply #3002
[SIZE="7"][COLOR="darkred"]3,000 posts!!!!!!![/COLOR][/SIZE]:drink:
Reply #3003
Take the little cross member thing and build a little shadow box for it and hang it on the wall.
Reply #3004
I'll just hang it on the wall with the small section of quarter panel that didn't have rust either...lol
Reply #3005
You can name it "once upon a time................"
Reply #3006
a little more done, and even closer to the finish....
installed rad hoses, throttle cable cruise cable, HORNS........ hood release, trans cooler, misc other small ticket items....
are these for anything important?
I assume this is for the light under the hood
Reply #3007
Jerry, the last picture is the connector to the hood lamp.  Some hoods had them, some didn't.  In the second to last picture, that plugs into your EGR position valve sensor (EVP) on the back of the EGR valve - you can see the connector on the back of the EGR in your picture.
I'm not 100% sure on the other ones, but it looks like A/C related.
Reply #3008
Quote from: The Shredder;364089
Thanks, I couldn't see the plug under there...I also have a hood light
Reply #3009
In the third picture, I believe that pigtail is for the sensor for the temp gauge on the digital dash. The buttstuffog gauges uses a one-pin connector there, but the double is also apparently present, as it is on my car with buttstuffog.
Reply #3010
Quote from: hwy73;364092
In the first picture, I believe that pigtail is for the sensor for the temp gauge on the digital dash.  The buttstuffog gauges uses a one-pin connector there, but the double is also apparently present, as it is on my car with buttstuffog.
I agree. I have base cluster and that plug is connected to thin air in mine e/c as well.
Reply #3011
I had a feeling it was for that..... the next pic after that one will finish the connector questions
Reply #3012
I can check mine tomorrow and see where they connect if you want.
Reply #3013
Jerry, is your hood latch bracket bent? It looks curved to me. maybe it's the picture. Exactly which plug are you needing to know about now? There's a couple on the Sport that have no place to be, just hanging there.
Reply #3014
it would be the connector in the 4th pic I posted yesterday... down under the battery area with all the fusible links and connectors...
My bracket always had a bit of a curve to it since the car was new...... never understood why...  I'll try to straighten it when I put the front back on for good... I'm thinking the car was welded together a bit wrong when the car was built....I remember things were a bit off when I was replacing parts and panels, and a ton of factory shims on one side of the fenders, and nothing on the other side.....
