Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1531296 times) previous topic - next topic
Reply #2070
You should be able to use the drive shaft that was in the Cougar with the 5.0 AOD combo. I'm 99% certain that the 3.8 and 5.0 cars with AODs used the same length drive shaft.
Reply #2071
Quote from: thunderjet302;315950
I never had that combo, so I'll try with the 3.8/ AOD combo. I'm pretty sure it won't be a problem.
Reply #2072
i know there was a chart of the variouse drive shaft leingths years ago but im not sure where to find it now. It had a combo on 3.8-c6 then 3.8-AOD and 5.0-AOD.
Got that fox rash again!
-Resident smartass! :ies:
Reply #2073
I'm pretty sure you can, because the trans mount still bolts to the same spot. The aod is no different externally!
Reply #2074
Quote from: Kitz Kat;315972
X2.But,get a Crown Vic shaft and have it shortened before you need the driveshaft,Just start out with the aluminum one.They can be found wicked cheap at the yards,and well,you know the rest of the shortening story.;
Reply #2075
you have to remember.... up here, good parts are expensive. not like where you live Vinnie
Reply #2076
We're getting closer.
Reply #2077
I didn't know they cost a lot there.I actually thought they were cheaper. I did know they were rusty though.LOL.
Reply #2078
Wow... Wow..
WOW
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
Reply #2079
Quote from: vinnietbird;316017
Actually it's everything here is expensive from taxes, to gas, to food. Gotta go out west to the mts of New Mexico
Reply #2080
And, I know the pics are a bit blurry. The flash was glaring of the car, and I had to shut the it off. Unfortunately, I didn't hold the camera steady long enough for the pics.
Reply #2081
Out here,it's free to go into the yards,and when the guy says "$10.00",then it's $10.00....not "plus tax,etc.".Usually,I can fill a large duffel bag (I use it to tote parts at the yards) with a bunch of small parts and he'll ask for $20-25.00.
Reply #2082
The passenger door looks a little misaligned...or is the fender?
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Reply #2083
Quote from: Quietleaf;316048
looks fine in the last pic. Unless I'm not seeing something.
Reply #2084
also, the doors are not closed. could be what your seeing. I spent 8 hrs aligning the entire front of the car one Saturday
