Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1536981 times) previous topic - next topic
Reply #1515
How is the car going to be geared?  Overdrive sure is beneficial with any highway driving if running lower rearend gears...
Reply #1516
Take the convertible out on the highway and shift out of OD into D and drive for a bit. If you think you can live with that, go with the C6 :hick:
Reply #1517
It's got a 8.8 w/3.73
If I cruise it around the Island, I never really drive faster then 45.
the vert made it to OD 2x since I've been driving it.
Don't think highway driving will be an issue with this car
Reply #1518
C6 with 3.73s mmmmmmmmmmmmm, i've done a C6 with 3.70s in my old 75 cougar.
Revved around 32-3500rpm at 120k,kinda high in my opinion.
Get an aod out of an SC(preferably) or mustang(should be pretty cheap).
I have a rebuilt one out of an SC jerry but i just don't think i want to part with it(good spare since both my car's have aod's).
Look over on sccoa, you may find one fairly close for cheap.
Reply #1519
best advise of the day!
hardened input shaft as well on the sc aod......per tom.,, he should know.
next up would be valve bodies with a letter grade or stamp of "A" or something along those lines.
all of this gets you the best trans pretty cheap.
pm tom,,
Reply #1520
Yes the SC aod has the A overdrive servo as well as a wider and stronger overdrive band.
Reply #1521
AOD, AOD, AOD:D. Are you sure the shaft from the 3.8 won't work?
Reply #1522
Quote from: thunderjet302;283229
I was reading this the other day. I'm not quite sure if the difference is just with an 88, or all 3.8s. Or for that matter, if there will be a difference that I'll run into.
I'm just be overly cautious and doing my research now before I get to that project.
Quote from: TurboCoupe50;283020
http://www.foxtbirdcougarforums.com/showthread.php?t=23840&page=2
A T5 shaft is close to the same length of a 5.0 AOD Bird and will interchange... A TC A4LD auto shaft is approx 5" shorter than a AOD shaft... A 3.8 AOD D/S is apparently a different length(see link)...
So, does anyone have the exact length of a DS for a 5.0 with a 8.8 rear?
Is that the correct length of the DS, in that link?
Did anyone ever use the DS from the 3.8 in there 5.0 swap?
Reply #1523
On topic, aerostar D/S 's are aluminum.  You have to transfer your yoke.  The gain is weight loss.
Reply #1524
Quote from: jcassity;283263
SC AOD. Aerostar WELDED, not stamped shaft.
Jerry there is an 87-88 out at the yard. I didnt look at the lid though. Just had to back track about 10 pages.
Reply #1525
What about a Crown Vic Police Interceptor aluminium drive shaft cut down and balanced?
Reply #1526
Quote from: thunderjet302;283278
I've been thinking about that.
Reply #1527
Do the aod I have one out of a 91' 5.0 stang with a trans-go kit and a B&M 3000 holeshot
converter and I run high 11's with no problems, it just gets hot on the highway because I was too cheap to buy a lock-up converter
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #1528
Yea, I'll probably use my AOD... I'll deal with the DS after the motor is back in I guess
Reply #1529
Quote from: daminc;283364
A wise choice.;)
