Topic: oil sensor (Read 3548 times) previous topic - next topic
oil sensor
When I start my car, half the time my full digital dash warns me the car is low on oil. It isn't, though, as oil was changed about 300miles ago. I hoped that would solve the issue with the low oil warning, but it hasn't. After I drive around a bit, the gauge correctly shows 4 bars out of 4 (if 4 is the maximum, that is :) ). Is it time to replace the oil sensor? Or is there anything else I can check?
oil sensor
Your pressure is good and your level is good on the dipstick its probabably the level sensor on the oil pan or wiring to it. Is there somehow to jumper the sensor to send a signal that the level is good? Then you can prove the sensor is bad?
oil sensor
I know in my 84 T/c I was looking for the O2 ground wire that was orange. I found 2 of them. One was the O2 ground and the 2nd was the wire for the low oil light on the dash. If I grounded the wire it made the LOW OIL light come on. So maybe you have a piece of that wire shorted to ground.
oil sensor
Ok, thanks. So where's the sensor located? It's an '88 5.0 V8 engine.
Is it possible to take the sensor out and perhaps clean it? The guy who serviced my car told me the oil filter was clogged up and the oil was thick and old, and perhaps some dirt prevented the oil sensor from working correctly. Don't know if that makes any sense
oil sensor
Low oil sensor is in the side of the oil pan, driver's side.
If cleaning that sensor off, and/or replacing it, does not solve the beeping issue then it's in the wiring. You have a bunch of wires running on the driver's side of the engine bay...in that mess is a wire with a grey shunt attached. I believe that's the one that goes to the oil sending unit above the oil filter. There's where you should look for the problem...several people have mentioned that before. Will (weasle) told me that the shunt ended up being the problem on his '87 XR7 with the digital dash.
oil sensor
Can I take the sensor out w/o spilling any oil? Any precautions necessary before doing it?
oil sensor
You talked about the guage showing bars.....Do you mean the OIL PRESSURE SENSOR?
Quote from: EricCoolCats
You mean this below?  It's a 22 ohm resistor.
http://www.foxtbirdcougarforums.com/showthread.php?p=36134#post36134
oil sensor
I was under the impression that's an oil level display? How else does the car warn you it's low on oil?
oil sensor
There's an indicator light for that.
Get a mechanical guage and check your pressure at cold idle, hot idle and @ 2000 RPM's hot.
It SUPPOSED to go off at around 7 PSI.  Mine would chime at 20 PSI.  Annoying to say the least.
oil sensor
ok, sorry for my unawareness of the gauge...
if the pressure's low, isn't it supposed to be beeping and blinking every time I drive the car?
oil sensor
Quote from: thebruins;190300
4 bars? Mine is at 5. My guess is your oil pressure is low. If the engine was neglected (hence the plugged filter, ie slidge) and run with a clogged filter who knows what the hell happend to the bearings and such.....
oil sensor
No.  Many things will affect it.
oil sensor
I want to start by replacing the sender unit, and see if that fixes it before having it checked out by someone else. At http://www.motorcraft.com there are two units to choose from, one 'w/light' and one 'w/gauge'. Also, at http://www.partsamerica.com they make a distinction between senders for mechanical and electronic clusters. Is the sender for electronic clusters with a gauge the one I should get?
