Topic: Final Count Down!! (Read 2513 times) previous topic - next topic
Final Count Down!!
my father wants a list on what i want for my motor in 2 days. i have a 4grand limit. i was thinking on a HO and a blowzilla, flowzilla KB blower it should produce around 350RWHP with my underdrive pullies and full exhaust.
does that sound good?
Final Count Down!!
heads/cam/intake and a nice nitrous kit and have money left over
Final Count Down!!
heads/cam/intake/cold air kit/under drive pulleys if you want/3.73 or 3.55 gears/stall and shift kit and trans cooler
Final Count Down!!
350RHP and a 4000 dollar budget is tuff a rebuild is half your budget so a power adder is your best bet. if you choose a PA tell your machine shop first
If you’re doing a stock rebuild you can get set of gt40 or gt40p irons at a bone yard cheap.
Intake 96 and up explorer are gt40
On your cam selection when ordering inform the of what trany your using converter speed and WHAT POWER ADDER you chose.
Maf conversion a must
I paid 200 for my gt40 heads from my local J/Y and 150 for U & L intake
Try and leave extra in the budget for a brake upgrade don’t for get for going quick you gotta stop.
Final Count Down!!
Quote from: Carpimp1987;188513
WOW i think this is one of the only times i have agreed with Carpimp.... an prob. the last.
Smog delete, hi torque starter, MSD dizzy coil and box.
Final Count Down!!
Pull the AOD, put a 2800 or 3000 stall, Shift kit, A+ servo, New clutches and everything.
Pull the rear, 3.73's or 4.10's, New clutch pack
Pull the motor, gt40 heads(cleaned up) exploder/cobra/gt40 Intake, Get a cam, do a mass air conversion, headers.
Put all back together, and drive it and be AMAZED on what that does for the car.
Forget the supercharger on a stock AOD, and stock rear end. Its like trying to pull a car using a giant 4 ton tow hook, and a piece of string.
Final Count Down!!
The KB will help get that brick moving even with stock rear and tranny :D
Final Count Down!!
KB's build up alot of heat. They don't have an intercooler kit for the 5.0's and it would take alot of fabbing. Granted, a KB with heat would be better than no KB and cold air. You could also get past the heating with a small N2o shot.
Final Count Down!!
Quote from: Cougar5.0;188986
Never said it wouldnt, but I think his money would be better spend building a good base motor, and setting up the trans and rear for the extra power. Not my car though
Final Count Down!!
who cares? he just wants a dyno to tell him he has 350hp. then after daddy dumps $4k, he could keep up with a stock Grand Prix. LOL!
1979 Ford Fairmont
[/B]
Final Count Down!!
true its not my car
Final Count Down!!
Quote from: Drewstang;189027
We don't need no stinkin' heat! KB's are fine in northern areas that never get that hot.
Final Count Down!!
Quote from: daboss351;189032
agree 4000 wont go far
Final Count Down!!
Meh, it's not the power level, it's the power level and IF he hooks WHAM!;)
