Topic: Cobra and HO duration...? (Read 3796 times) previous topic - next topic
From what I've found,
GT(HO) = .444 lift
Cobra = .451 lift
What is the duration for both of these cams?
Code: [Select]
HO Cam
Intake -  .278" - 276 degrees
Exhaust -  .278" - 266 degrees
Cobra Cam
Intake -  .282" - 270 degrees
Exhaust -  .282" - 270 degrees
Source: Kirschembaum
Can you get me the specs @.050?
Quote from: 88XR7;187925
IIRC HO cam durration @50 is 210*I/210*E
Also the HO cam is actually more aggressive than the Cobra cam.
From what I've found the Cobra cam produces more torque then the HO Cam, but the HO has 15ish more hp.
Going from SO to HO cam would I notice a decent increase in power?
How would the SD be with a B303 cam?
HO cam figures are with 1.6 rockers.  Cobra is with 1.7.
93 Cobras were rated @235 HP, about 40 HP underated.  Different heads and intake were the main reason.  A Cobra motor with an HO cam and the Cobra 1.7 rockers would have been an even better combo from the factory IMHO.
Go with the HO cam.  Back it up with some 1.7 ratio roller rockers and have a ball!
Well, the bottom end is being rebuilt since it start knocking.
I figure why not do a cam and a stall at the same time?
So, looks like it will be a HO motor without the upper basically, with Hooker Supercomps(Shorties, they were free!!) and a stall rated from 2000-2600.
Should move the pig somemore...:hick:
Anyone know about running a b303 though?
^^^ interested as well i jsut finished the E7 head swap and the HO conversion is next on the list.
2004 Impala
My understanding the initial cobra cam was suppose to be more aggressive but the motor idled to lumpy ford built the motor around the 1.7 RR so they wanted a less aggressive cam the cam they chose was the cam commonly put in 91&92 5.0 tbirds and cougars. That’s right the exact cam.
Quote from: V8Demon;187972
93 Cobras were rated @235 HP about, 40 HP underated.  Different heads and intake were the main reason.  A Cobra motor with an HO cam and the Cobra 1.7 rockers would have been an even better combo from the factory IMHO.
I was just going to say that....  you beat me to it.
That's what I'm running in my cougar...picked up big time...my problem is the 1.7rr's I bought didn't come with shims so they are currently pre-loading the lifters about .120", which is about 4 times too much pre-load...it gets pretty lazy around 3200rpm...I think it'll be much happier when I put the stock rockers back in.
The HO cam was just a poorly designed cam for the E7's due to the fact it has 10* more intake duration than exhaust duration and the E7's have itty bitty exhaust valves...I can tell you that the HO cam runs great with '93 Cobra heads though, courtesy of the larger exhaust valves.
Does anyone know of a way to tell an HO cam apart from an NonHO cam?
firing order.  the lobes will be in different spots on the cams
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
and all I have to do to swap that is swap over a few injector clips and I'll be good to go?
Speaking of cam specs, I don't suppose anyone has the lift, duration, and duration @ .050 information for the roller 5.0 SO motor's cam, do they?  Just curious as to exactly how small it is compared to the HO cam.
1988 Thunderbird Sport V8 - only 1 previous owner, and 110% bone stock so far... and sold to Nate!
