Topic: Cobra and HO duration...? (Read 3792 times) previous topic - next topic
@ Cam:
Intake:  .2375
Exhaust: .2474
X 1.6
Intake:  .3800
Exhaust: .3958
X1.7
Intake:  .4037
Exhaust: .4206
How would the Cobra cam cmpare to the E303 (I ask because I have an E303)? I'm still waiting to install my E303 in my car.That should help over the H.O cam I'm using now,along with the roller rockers,Mass Air and exhaust,the car should scream.......I hope.
I’m sorry the cam ford designed for the cobra was also put in 93 thunderbird/cougar 5.0 200 HP motor.
Just got done reading it
Quote from: 88XR7;188304
and all I have to do to swap that is swap over a few injector clips and I'll be good to go?
Swap the cam and computer. The HO computer takes car of the fireing order change. You DO NOT need to change the wiring at the injectors.
Did the SO also come with 1.6 rockers, or 1.5?  If the latter, then "y" doesn't even begin to describe the SO cam, given the specs V8Demon quoted!
1988 Thunderbird Sport V8 - only 1 previous owner, and 110% bone stock so far... and sold to Nate!
Quote from: thunderjet302;188551
i just read coolcats cus of the swap i'm doing. aparently you need a MAP sensor also. im glad i read that, cus thats someting i totally overlooked.
Quote from: King_V;188561
they got 1.6 as far as i know. thats a big difference tho. .380 on the SO and .444 on the HO. i didnt think it was that dramatic of an upgrade.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
Stock rockers are 1.6
All 5.0 engines have 1.6 except for the Cobras...
The SO cam can be best described as a POS....
Quote from: grutinator;188593
Yeah I'd change the MAP sensor to a HO one. I had funky idle problems with my SO sensor that cleared up when I put a HO one in. Actually I used a Mustang BAP sensor but it's the same thing ;)
Quote from: TurboCoupe50;188606
Believe me I know ;)
Well, I wouldn't say that . . I'd say it served the purpose for which it was designed - maybe not in the best way imagineable, but still...
Gotta remember too, when the 5.0SO SEFI came out, it was putting out power numbers that one would typically expect of a 2-bbl 351 in the 1970s, which isn't anything to sneeze at given the era.
The SO cam was primarily profiled for torque output at low sub 2000 RPM and not peak horsepower, at the same time keeping gas consumption at a level heavily concentrated on during the CAFE 80's. Thus why it was used for the Crown Vic with E6 heads (another torque before HP design), and also the F150 with E7 like heads and one large air hungry intake system. It also copied the profile and firing order of the non roller 302 cam used before the intro of the non roller HO 302. It served its purpose well for a big bore short stroke block. That said...HO RULES!!!
87 Sport with HO cam, 19# injectors,TB+Upper Intake,87 Mustang EEC, Cloyes double roller timing chain, Kirban adj. fuel regulator and Autometer fuel pres. guage, HO shorty headers + LSC H-pipe and Dynomax Super Turbo lers, Ford Racing 9mm wires, K&N filter / no air resonator, 8.8 XR7 Diff., V rated tires, Project ongoing.
