Topic: Work in Progress - DIY Frame Rail Replacement - 56k Hell - Updated 11/15 (Read 13880 times) previous topic - next topic
Reply #75
I guarantee that 50' cord is your problem.
Mine does not work very well unless it is on the very shortest cord possible...I think like 5 feet max.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Reply #76
Here's a good site on decoding welding rod numbers.
http://www.jeep-l.net/info_jeep/weld_rod.htm
:pics-stfu:
 Project Thread with pics
Reply #77
Quote from: Red_LX;188518
Mine runs great on a 100 ft cord, :dunno:  of course mine is a lincoln handy pak though.:shakeass:
Reply #78
I have a Miller 175 and it works great on my 50' extension. It also depends on how big/gauge the extension is. The longer you go, the Bigger wire needed so there isn't as much of a voltage drop. It'll still happen but not as much. Just my .02 :D
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Reply #79
I bet thats stronger than the factory setup.
Reply #80
I have a cheesey little craftsman MIG and it works fine on a 100' cord...you just need to make adjustments to your heat/feed rate.  Flux core wire is much more difficult to mig with than using an argon/co2 mix for shielding purposes.
Good luck and keep the updates coming!
-Don
Reply #81
This is what happens when front frame rails are stick welded in.
Reply #82
Whatever happened with this project?
anyone know?
Reply #83
i often wondered,, was this your inspiration?
Reply #84
No it wasn't. It's really hard to explain the projects that inspire me.
I've replaced so many panels and painted so many cars in the last 20 years, that the next project, I try to out do the quality of the last.
I had a lot of practice bending up replacement panels for my father-in-law in the last 15 years.
I guess the old classic car restorations are what inspire me the most.
As I was looking at the frame rails on my car, this thread came to mind.
