Poll
Should I cut the other spring and lower the whole front or get new stock springs?
Total Members Voted: 25
Topic: To lower or not to lower... Now with Mach1 springs = lowered! (Read 3557 times) previous topic - next topic
Definitely lower it, it looks a lot better ;)
Matt
OK, I cut the other spring. Looks good though the car is still higher on the passenger side by 1/2" :(
Also, the drivers side tire ishiznitting the wheel well - 3 times already.
I tried turning one of the rear springs 1/2 turn but it just made it worse.
I think I will need to get a bump-steer kit, though the tire easily hitting the wheel well is my first concern.
Any suggestions?
OK, the spring rate of stock springs is too low when they are cut. I am hitting the fender with the tire regularly now. I realized after doing some research that a lowered car needs a higher spring-rate to keep the tires/front-end from bottoming out. I think the recommendation of at least 600lb/in rate for a lowered car is about right. I found a used set of Mach 1 springs (600 lb/in) for a good price so I'm going to use these. These should lower the car about 3/4" to start and I will cut the coils to get the exact height I want. The Mach 1 & Bullitt springs look like a good deal for our cars IMHO. See the "Spring rate and drop" table I recently posted in Suspension for more info on springs.
The lowered car actually could make a case that it doesn't need a ground effects kit now.  I would actually raise it just a tad.
OK, I got the Mach1 springs today and installed them immediately (took only an hour - I am an expert at this by now - lol).
BEFORE:
AFTER:
BEFORE:
AFTER - the drop is about 1" - 1 1/4" :
I also measured the springs before installing them - this is the Mach1 spring versus the OEM spring WITH ONE COIL REMOVED!
As you can see, the OEM spring is about 15-15 1/2" long before cutting, the Mach1 spring is about 13" long. The difference is in the spring rate.
Oh, the ride is so far very nice. I am NOT bottoming out AT ALL now even though my street is being paved and is bumpy gravel. Also, I did not change the struts, but the replacement Gabriels that I have were always punishing - I remember getting them cheaper as the guy at NAPA said they had re-valved them in the newer model. All I can say is, they were too stiff before and now they work well with these new higher rate springs - my bumpy gravel road hardly felt bumpy at all after adding these springs which is a good sign.
Those look a bit higher than the first go around.  It looks better.
Good info, I'm about to the process of Installing my 99' GT springs
Looks mean as hell!!
Quote from: Sduneman3;179541
I will provide updates going forward, but so far based on first impressions, I will state that I believe that the Bullitt/Mach1 front springs (nearly identical) are a win-win fit for our cars. They lower the car just enough to get decent improvement in center-of-gravity without going overboard and yet they provide the increased spring rate that is needed when you lower the car to keep the fenders off of the tires. I am very happy with this mod!
Let us know how the '99 GT springs work out!
Quote from: Cougar5.0;179549
I will provide updates going forward, but so far based on first impressions, I will state that I believe that the Bullitt/Mach1 springs (nearly identical) are a win-win fit for our cars. They lower the car just enough to get decent improvement in center-of-gravity without going overboard and yet they provide the increased spring rate that is needed when you lower the car to keep the fenders off of the tires. I am very happy with this mod!
Will do, but I have some other things I need to get fixed first(frame rail) and then I'll let you know.  I'm also going to install some 03' GT struts
