Poll
Should I cut the other spring and lower the whole front or get new stock springs?
Total Members Voted: 25
Topic: To lower or not to lower... Now with Mach1 springs = lowered! (Read 3545 times) previous topic - next topic
Perhaps some of you have read of my escapades WRT changing my front end. It was all set into motion when I blew another power steering pump a couple of weeks ago. The bearing broke in the pump and filled the system with ground up metal. I figured it was time to put in a new pump, rack and find that larger PS pulley that I had heard about. OK, I did that. In the process I had to separate the tie-rods and at some point I fugured I should use this as an opportunity to throw on the M-3075-D control arms that I had laying around along with the 11" brake upgade that I figured I do at the same time (while I'm in there). SO after tightening up the rack for a test fit, I then loostened the a-arm nuts and gave each one a whack to "see it they will move". One didn't and that is a whole thread onto itself. After numerous hours grinding and cutting the bolt and then fighting the spring compressor, I got the first arm in. I then went to do the other side which I knew would be easy - except that I found the spring on the other side had a broken coil - doh!  Basically one complete coil is missing. I cleaned up the end of the spring with a grinder and assembled it.
Look at the pictures below - one side is the (unintentionally) lowered side, the other is the side with the normal uncut spring. Now, here is the poll question (finally, you thought I'd never get around to it!):
Should I cut the spring on the other side to match - thus lowering my car the amount shown (and it looks like I'll have some bump steer based on the angle of steering rod), or should I get new stock springs and set it back to original height?
OEM Height:
NEW height:
Decide for me quick because driving around like this may get to be annoying :hick:
LOWER IT!!! It LOOKS MEAN!!!
lower the rear also
Quote from: SLEEPER T-BIRD 87;176552
lower the rear also
I was think of that. I have the CHE adjustables and they lift the rear a little which compensated for some sag and lets me run 28" tires. I have kind of a dillema here as I need to be able to fit the 28", 11.2" cross section tires on there.
Depending on the severity of the tie rod angles.  It doesn't take much to throw the angles off.  My 88's are horribly uphill.
lower it!  I did mine and it was a big improvement.
:pics-stfu:
 Project Thread with pics
Lower it.I'm going to lower the front of mine by an inch.It sits high like yours does.
Another vote for lowering. I think the new ride height looks much better. I think you nailed it. It doesnt look too low in the front in relation to the stock height in the rear. I did the same thing on my 87. I ended up cutting off one full coil off the fronts and leaving the rear stock.
Well, this is what I expected and I'm glad everyone so far agrees that it looks better lowered. A side benefit is that I can get the spring in without a spring compressor :) Since I grew up with cars slightly angled downward (air shocks in my GTO - lol), I can live with the rear a little higher. I may go with 27" or 28" street tires in the rear too which will make the gap above the tire about equal. Or I might eventually get some slick 18" wheels and use a 27" tire in the rear with a 26" in the front...
(chanting) Lower it! Lower it! Lower it! :welder:  :welder:
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
lower it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                        :birdsmily:
Quote from: Cougar5.0;176556
should be no problem
And of course, lower it.
I would get some c/c plates and fix that tire wear!
Quote from: CougarSE;176681
I might consider it, though I lost the -2 degrees of camber I previously had (not sure why) which had to be effecting tire wear somewhat.
