Topic: Exhaust droooooooooooooooooooooooone! (Read 3272 times) previous topic - next topic
Ok guys I'm currently running 2.5 inch pipe with cats and mac prochambers and the drone at 40mph and 55-67mph is excrucitating! what I'm wondering is what kind of setup I need to run in order to eliminate drone.
Do I either need to buck up and buy a bunch of sound deadening or do you know of any type of ler that has little to no drone.
First did you remove your sound deadener? Second what lers are you running? I ran my without a ler just cats, and it droned, but not as bad as I thought. I have a magnaflow on and it quieted the car so much, but its really really deep. Everyone seems to put Flowmaster on 5.0s, and personally these Magnaflows are awesome and distinct. Just depends on what specific sound you want, and what your are going to run as far as the whole system goes.
Do you have tail pipes?If not,install some.
I have bad drone since upgrading to 2 1/2" all the way back. Got no answers for ya...
Exhaust from front to back:
Bkk shorty headers into a mac h-pipe with cats then into mac prochambers which exit through tailpipes that extend past the bumper.
I wonder if wrapping the lers and h pipe in thick header wrap would help?
Personally I'm looking for something that doesn't drone those are my only requirements.
drone comes with v8's
theres your answer
Dynomax Super Turbo's.
Quote from: nirvanagod;171223
droned for me too...
A MAC prochamber is just Mac's version of the "H-Pipe". With a little chamber replacing the crossover pipe. If you are only running that then you need some lers yo.
Maybe a nonchambered straight thru ler?
Flowtech Afterburners aren't bad (that's what I use).
this might sound silly, but try putting some higher(numerically) gears in the rear. "droning" usually occurs at a low rpm(1200-1800).
1979 Ford Fairmont
[/B]
Quote from: bhazard;171266
this would work, too. my truck had a glasspack on it, when i bought it, and it was quieter at cruising rpms, than the flowmaster i replaced it with.
1979 Ford Fairmont
[/B]
