Topic: Exhaust droooooooooooooooooooooooone! (Read 3270 times) previous topic - next topic
Normal with performance exaust,sorry man nothing you can do but goto a quiter ler.
I'm running magnaflows straight thru's,It's not bad,turned down at the axle for now,so sitting and running I no there there.Really not much drone when running.
So I called Flowtech and asked about the afterburner ler they claim that it has almost 0 resonance and have a moneyback guarantee if i don't like it. So Exactly how quiet is it at cruising speeds Thunderjet?
do what i do and let the stereo drown it out. :P
The whole point of the thread is to find a way to eliminate the drone. If I wanted to permanently damage my hearing I would not even address the problem and do just that. Oddly enough though I like my hearing and not having a ring in my ear.
Quote from: GrannysBird;171476
At crusing with the windows down I hear more wind noise than exhaust noise. They do rumble at idle and WOT though. I do have a catless 2.5" H-pipe which is connected to 2.25" lers and tails which probably quiets it a bit. Next year when I replace it with 2.5" lers and tails it will probably be a bit louder. Your cam will also affect how it sounds. I have a rumpy cam so the exhaust sounds rumpy.
Quote from: GrannysBird;171500
[SIZE="6"]WHAT? I CAN'T HEAR YOU![/SIZE]
I have a set of Flowmaster 40s if you are interested. Not sure if they are the supers or not they are kinda short and I can only see where one baffle is welded in the ler. I also have a set of Dyno Max turbos but they are 2.25 lers.
