Topic: strongest 7.5 LSD? (Read 9805 times) previous topic - next topic
strongest 7.5 LSD?
Reply #60
I'm not the best at this, if you buy Ford gears and not aftermarket I can most likely get them to work.  I always just used the same shims and spacers and always lucked out.
I know this is all wrong but it worked for me in the past.
Gears like these http://cgi.ebay.com/ebaymotors/3-73-gears-8-8-Ford-Mustang-GT-LX-F150_W0QQcmdZViewItemQQcategoryZ33731QQihZ018QQitemZ280141279905QQrdZ1QQsspagenameZWDVW  Looks like this guy sells lots of gears.
There are also some on ebay for $59.95 but the guy has terrible feedback.
TED
strongest 7.5 LSD?
Reply #61
hwo much more do you want for putting in the gears? i just bought new bearings and shims. and im buying a install kit, (gaskets and such)
would this be ok?
http://cgi.ebay.com/ebaymotors/Ford-8-8-Axle-3-73-Ratio-Gearset-Ring-Pinion_W0QQitemZ160146933363QQihZ006QQcategoryZ33731QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
strongest 7.5 LSD?
Reply #62
If the price stays there it will be fine.  Don't really need an install kit or new bearings.  Like I say I'm not a gear expert but we can try if you don't come back at me.
TED
strongest 7.5 LSD?
Reply #63
well, i'll just buy a cheap set of 3.73, kinda like the ones like i posted right above.
strongest 7.5 LSD?
Reply #64
it will be another learning experience...
strongest 7.5 LSD?
Reply #65
hey TED!
i found this one.
http://portland.craigslist.org/wsc/pts/395942135.html
but i cant send a message to the guy asking for pictures...
strongest 7.5 LSD?
Reply #66
Oregon!  Why not just get the one in Lacey for $25 more?  I'm confused.
1988
Rear Axle
Ford Mustang GT,302,5 Sp,RWD 111,000 A JJ4064 $175 Lacey Auto Wrecking USA-WA(Lacey) 1-360-413-0658
It cost me $15 in gas to go to Mossyrock and back tonight.
TED
strongest 7.5 LSD?
Reply #67
Just buy a whole rear, or spend the money to have it done right....I had 3.73 ford racing gears put in my old car and they still had to shim the carrier because it was off...you can get away with it sometimes...but nobody is lucky forever...
strongest 7.5 LSD?
Reply #68
i cant find the one in lacey anymore in craigslist, i looked, but this is the only one that i could find.
strongest 7.5 LSD?
Reply #69
It's at the wrecking yard in Lacey and I found it on part finders.  I posted the phone number for you.
1-360-413-0658
Not on Craigslist.
TED
