Topic: strongest 7.5 LSD? (Read 9782 times) previous topic - next topic
strongest 7.5 LSD?
You can change it.4 bolts,the nuts for the shocks,disconnect the brake lines,release the parking brake lines,out it comes.Reverse the process to install it.with a buddy,you should be able to change it in an hour or so.Get two jack stands,and a hydraulic jack.After I removed the rear,I put the tires on it to roll it where I needed it.
Be patient and keep looking and you'll eventually find a great deal.The standard fee for a TC rear around here is $150.00 to $200.00.Not too bad.
strongest 7.5 LSD?
If you find one I will put it in for you for $200 plus any parts you might need, like brakes.  You can help me and learn, I have a hoist and shop so we don't have to crawl around in the driveway.  Don't really know what we would do about the speedo if different gear ratio, have to buy a gear from Ford but you can only go so far one way or the other.
What year do you have?  Switching to 4wd brakes could cause other problems.  I think a Mustang rear would be about 1" narrower for each side but I don't think this is a problem.  Chuck will tell me to look this up under search.
TED
Olympia, 360-943-7604
strongest 7.5 LSD?
Quote from: vinnietbird;167811
Thanks for reiterating that for me vinnie...lol.
strongest 7.5 LSD?
hey Ted, thanks, when i find a rear end, you'll be the first person i let know! i'll look down there for a rear end. my cousin lives that way so he could help me look around for one. do TC rear ends come with a posi?
strongest 7.5 LSD?
Quote from: quicksilver;167839
h. do TC rear ends come with a posi?
Posi is a GM term... Yes all '87-'88 TCs have a 8.8 Traction Lock... The 86-earlier are 7.5"
strongest 7.5 LSD?
ok, thanks for letting me know! i'll check craigs list and see what they have
strongest 7.5 LSD?
hey, i found a rear end!! $75!! out of a 93 cobra. but i cant contact the guy!! i dont know how!!!
strongest 7.5 LSD?
Quote from: quicksilver;167843
hope you have different offset wheels to throw on. mustang rears  are narrower then birds
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
strongest 7.5 LSD?
Hey,I know what it takes to make it fit the T-Bird (width).Easy to do with a few parts..Right Chuck?LOL.For $75.00,make sure it is what thet say it is.That's really cheap.On the other hand,I got mine for $66.00.I did ask a lot of questions.Good luck contacting the guy.
strongest 7.5 LSD?
Reply #39
ted. i sent you the page that i found the rear end on.
strongest 7.5 LSD?
Reply #40
does anybody know how to contact through craigslist?!?!
strongest 7.5 LSD?
Reply #41
Also look for a Couger 8.8. This will make an easy change so you don't have to do a disk brake swap. Though, you won't have 3.73 gears, only 2.73.
So you have a V8.......isn't that cute.
strongest 7.5 LSD?
Reply #42
well 3.08 trac loc if u find an XR-7 or one with a towing package, not positive on the tow one tho
strongest 7.5 LSD?
Reply #43
oo im going to by 4.10 gears for it anyways.
strongest 7.5 LSD?
Reply #44
'93 cobra rear is virtually the same as a TC rear.
1979 Ford Fairmont
[/B]
