Topic: strongest 7.5 LSD? (Read 9811 times) previous topic - next topic
strongest 7.5 LSD?
Reply #45
Quote from: quicksilver;167851
does anybody know how to contact through craigslist?!?!
Just hit the link at the top of the page and it will take you to email.
The 93 rear on Craigslist does not have brakes and I'm not sure yours will transfer over.  Buying things incomplete may not be a good deal.
In the same ad he has a T-bird rear for free if you take the whole car, without title.  Maybe you can talk him into pulling the rear for you.  He says it a 8.8 with 3.55 so it sounds like a Turbo Coupe.
Also he said he may have a 3.73 rear in a couple of weeks out of a Mustang, this sounds like the best deal to me.
IMO 4.10 gears are too low.
What year car do you have?
TED
strongest 7.5 LSD?
Reply #46
The drums can work on a disk brake rear, you just need to use your stock axels, drums, backing plate.. exc. Thats what I'm doing for my 3.55 TC rear soon enough
strongest 7.5 LSD?
Reply #47
But if this is a Cobra rear could it be 31 spline in 1993.  Are you sure the axle width is the same?
I know we covered this before but I seem to think the 87-88 non-turbo housing was wider?
TED
strongest 7.5 LSD?
Reply #48
I forgot about that. Then it might not work. If you were closer, I could give you my spair rear I can get my hands on, a 3.08 TL 8.8 from a stang, already with Tbird axels and drums on/in it
strongest 7.5 LSD?
Reply #49
Here's some very good info.
http://www.foxtbirdcougarforums.com/showthread.php?t=13253&highlight=housing+width
The 93 Cobra is narrower than the 86-88 T-bird housing and the axles and brakes will not interchange.  Mustang did not go to 31 spline till 94.
I don't think the 93 rear would be the best choice if you do not get the brakes to go with it.
The Turbo couple woudl be a good choice but I don't think I know what to do about converting to 4 wheel disc.
I think the best choice is to find a 8.8 Mustang rear, it will be a bit narrower but you can live with it or adjust this with wheels.
TED
strongest 7.5 LSD?
Reply #50
You can ballance the offset of the stang' rear with the axels and brake setp from your old rear
strongest 7.5 LSD?
Reply #51
Quote from: 84 Fila;167895
I don't think so, the housing is wider in the T-bird, no work.
If you go to here
http://car-part.com/
It  will show you that Lacey Auto Wrecking has a 1988 Mustang V-8 rear for $175
1988
Rear Axle
Ford Mustang GT,302,5 Sp,RWD 111,000 A JJ4064 $175 Lacey Auto Wrecking USA-WA(Lacey) 1-360-413-0658
strongest 7.5 LSD?
Reply #52
I forgot, he has the later 7.5". I have an early 83-85.5 rear, the same as a stang'. Thats why I can interchange . Sorry
strongest 7.5 LSD?
Reply #53
is i get a mustang rear can i still have my 275'2 on it?
strongest 7.5 LSD?
Reply #54
I did not know you had the wide tires on there already.  You need to look at the inside to see if you have 1 inch plus of clearence.  If your wheels have a 5.5 inch offset than you are okay, if they have 6.5 you are not.
Just look under the car and see how much clearence you have on the inside.
TED
strongest 7.5 LSD?
Reply #55
i have a inch or 2, so its ok then? i'll just look around for a TC rear end so i dont have to worry about that.
strongest 7.5 LSD?
Reply #56
and at the top of the link on criags list when the email thing pops up, i dont know how to send it. i dont know what Cc means.
strongest 7.5 LSD?
Reply #57
Quote from: quicksilver;168019
If have a inch or two it would be better with the Mustang.
TED
strongest 7.5 LSD?
Reply #58
Quote from: quicksilver;168020
you dont have to worry about that. just fill out the subject line and body. then click send.
1979 Ford Fairmont
[/B]
strongest 7.5 LSD?
Reply #59
TED, do you know how to out in gears too? i want to by a set of 3.73 gears too.
