Topic: Power Window Motor Tips (Read 2370 times) previous topic - next topic
I just fixed my Son’s bad Window Motor on his 85 T-Bird.
Luckily it was only a worn out gear, $ 20.00 replacement part.
A lot cheaper than replacing the whole motor.
Here are the best 3 post I found on this site to find a fix for this.
http://www.foxtbirdcougarforums.com/showthread.php?t=12287&highlight=Door+window
http://www.foxtbirdcougarforums.com/showthread.php?t=14812&highlight=Door+window
http://www.foxtbirdcougarforums.com/showthread.php?t=14573&highlight=Door+window
I took some pics as I went along to help out the next person to enjoy this repair.
Sweet pics.That'll surely come in handy for someone down the road.Glad to hear it wasn't a worse,more expensive repair.
How big were the holes you had to drill?
Mike
Quote from: mcb82gt;283475
lol,, thats not even a valid question when you have the answer already:D
a hole big enough for for the socket required:evilgrin:
Quote from: jcassity;283531
Or... a hole big enough for the extension.  The socket could just meet it inside at least on a couple of the holes.
kinda dumb huh, wondering if I needed a 1/2  chuck drill.  LOL
Mike
Some can get by on this job by using the old gear and three 1/4" nuts. The edges can be sanded down.
Thanx for the pics.
2003 Marauder 300B
1996-97 Cobra wheel straight but weathered (For Sale)
84 TC manual shifter handle no  (For Sale)
BTW, I had a 1988 T-Bird Sport way back when. I found out that it was totalled shortly after trading it in. It still has the ignition switch recall to date.
Special thanx to EricCoolCats for showing me to this site.:bowdown:
I just did this on my 86 and had already fixed my sons 83. I only replaced the small inserts that break as the gears were still fine. These are the same set up as on my 65's, my 70, and 76 Birds. The other thing I did though was to take the motor apart and clean the contacts in the base. On my sons car if the window was left in a certain spot it wouldnt work. When I took it apart after the 3rd time I decided to open up the motor and look at it before putting in a new one. Glad I did as once I cleaned up the contacts and replaced the dew wipes it has been fine for the past year and a half.
Quote from: Ifixyawata;283542
extensions are generally assumed to be narrower than the socket you put on the end (in this case)
Quote from: jcassity;283732
Exactly.  I was saying you could drill a smaller hole.
Quote from: mcb82gt;283548
Or you could use one of these.
I tore into the door to get a look at whats going on.
The 2 clips that are glued to the glass to push it up and down have let go their bond.
I read on Coolcats, that no one has had any luck with glues and epoxys.
What about rearmirror epoxy?  Should bond to glass???
Mike
See if you can get a windshield epoxy, that's what I used on mine and it hasn't budged. However I baked mine in a paint booth for 3 hours, so you'll have different results.
http://foxtbirdcougarforums.com/showthread.php?t=22201&page=3
Heres a recent thread.
Quote from: mcb82gt;283882
hogwash,
and the topic has been here many times.
Want it to stay and never come off?
Gorilla glue (read the instructions and honor the amount you **NEED** , not what you think you need)
Want it to come off again one day for any reason you see fit>?
clear silicone.
