Topic: windshield trim (Read 3084 times) previous topic - next topic
windshield trim
It's been a while since I worked on the 80's.
Whats holding it on? can I pry it off?
windshield trim
pry it off, but be careful no to bend.
:birdsmily:
windshield trim
Well i havent removed front or rear, But the quarters are held on by A LOT of black thick gluey goopey stuff, I just carefully pried them off.
Windshield should probably be the same.
windshield trim
Little clips actually found my molding tool lookin for my body hammers.Thanks for the reply.
windshield trim
*smacks forehead*
Thought you meant the glass itself.
Yea little clips hold the trim, And gotta be really careful not bend or crease it as your pry like mentioned before.
Just wondering
Has anyone tried painting the trim that goes around your windshield?  Mine looks like ass :shakeass:and I'd like to touch it up.
William
windshield trim
Quote from: 88 Blackbird 5.0;324884
Like this?
and the back
windshield trim
I also painted mine.I used a satin black and it turned out great.
windshield trim
Quote from: vinnietbird;324911
Yep. rustoleum satin black
windshield trim
And where do you have the wippers in park position? Are they on the glass or not? I have them on the glass and the trim is damaged, because the driver's wipper hits the molding every turn a bit.
Omg!
Quote from: daminc;324886
Like this?
and the back
Your Cat looks absolutely sick!  I love it!  Rustoleum Satin Black it is.
I'll be as carefull as I can.  I saw a couple of you said these trim pieces are easy to mess up when you remove them from the car.
Thanks for the info guys.
William
windshield trim
I used dupli-color trim paint works great also
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
windshield trim
Quote from: Trinom;324923
I don't have them on the car in that pic. but in park, they should be to the edge of the glass. here''s a pic without the hood on, they actually hit the washer squirter blocks.
If the wipers are already down that far and are still hitting the window trim.... You may have the wrong size wiper blades on the car
Rear Window Trim?
Alright guys.  I took the windshield trim off, prepped it, painted it and reinstalled it.  It came out great!  I used Duplicolor's "Trim Paint."  It looks factory.  What a difference.  :D
Now...  Does the trim around the back window have the same type of clips holding it on?  What's the best way to take it off without screwing it up?
William
windshield trim
pretty much the same thing on the back. Just thinner clips
