Topic: windshield trim (Read 3105 times) previous topic - next topic
windshield trim
Quote from: 88 Blackbird 5.0;326133
Alright guys.  I took the windshield trim off, prepped it, painted it and reinstalled it.  It came out great!  I used Duplicolor's "Trim Paint."  It looks factory.  What a difference.  :D
Now...  Does the trim around the back window have the same type of clips holding it on?  What's the best way to take it off without screwing it up?
 What year and type are you working on? I assume an 88 Bird? The rear window trim in these cars are plastic snap in, correct, not the aluminum type like the fronts.
John
windshield trim
Quote from: hcor;326151
Some are snap in ,some are clips , I have no idea what is the deciding factor
windshield trim
You were right Daminc.  There were small clips, similar to the ones on the windshield.  This car is an 87 by the way.
I tweaked some of the rear trim pieces a little taking them off, but I was able to bend them back into shape luckily.  The clips were so tight, there was no way to avoid tweaking them a little.
I carefully straightened the pieces, cleaned them up and then painted them.  Tomorrow, they'll be ready for installation on the car.
Thanks as always for the help guys.
William
