Topic: Which speedo gear (Read 3659 times) previous topic - next topic
Which speedo gear
Which speedo gear do I need for an AOD and 3.55 gears?
Which speedo gear
what tires size? how many drive teeth on the AOD speedo drive gear?
this  is the calculator i use. scroll down for calculators, part numbers, and driven gear colors
Which speedo gear
my tires are 255 40 17 and as far as how many teeth the aod inner gear is,how the  do I know.I know the gear I have now is for a 2.73 rear.
Which speedo gear
hrrmmm, try findin an AOD specific speedo gear calculator?
i know how many teeth T5's use, but i cant help ya on AOD stuff.....
Which speedo gear
I recall reading somewhere that they are either 6 or 7 tooth. Have you done a search here, I think someone said that that was one of the differences between the mustang and tbird AOD's. Its been a while.
Which speedo gear
If it's an original TB v-8 it should be 7 tooth.Mine was but I don't
know if it was original.
Which speedo gear
ok then. calculator says 20tooth driven gear(p/n C8SZ-17271-B, orange) for 25" tire, 3.55 rear gear, and 7 tooth drive gear auto.
that page also states AOD's use 7 or 8 tooth drive gears, but i dont see any info on determining which you have.
*edit, what color is your stock driven gear for 2.73's, and what was the stock tire size? we can work backwards and figure out what drive gear you have.
Which speedo gear
Aod's out of bird's and cougs are 8 tooth drive,mustangs aod's are 7 tooth drive and t5 manuals are 6 tooth.
There is no ford gear for what you want to do vinnie,you have to go with an aftermarket 23 tooth off of ebay.
I had one once before i put in the stang aod, it lasted 2 months before loosing teeth due to the thiness of the gear.
My current aod is from a stang and is a 7 tooth drive with a ford 21tooth(highest ford aod gear) with 3.73s and it is within 1 km+ - on the dyno.
With my old bird aod(8 tooth drive) i had to go with a 23tooth to make it accurate with the 3.73s.
The max gear you can use and still use a ford 21tooth speedo gear is 3.27s,otherwise you just have to live with it being inaccurate.
Which speedo gear
I'll try a 23 tooth gear and have someone pace me on the highway.Thanks a lot.
Which speedo gear
Oh,this 23 tooth gear,....I've seen them for 5 speeds,but not aod's on ebay..
Which speedo gear
try ford racing they sell all the different sizes
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Which speedo gear
10-4 and thanks.
Which speedo gear
I got a 4-pack of speedo gears from CJ Pony. They are for sale but they are for a T-5. I think they have AOD gears as well.
Which speedo gear
just a side question...
how much would getting bigger wheels and tires(overall diameter) change the difference in the speedo gear. for example, if he needed a 23 tooth gear and could only find a 21, would that compensate for the difference much? i ask 'cus either 3.55's or 3.73 are the next planned mod, i wanna know what im up against.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
Which speedo gear
http://www.mustangsunlimited.com/itemdy01.asp?T1=DFM17271J+01&Category=Drivetrain&subCategory=Speedometer+Gears&CatKey=74-01
Have had this in mine for over a year with no problems. If you have the stock AOD like me this is the one you need.
