Topic: Which speedo gear (Read 3666 times) previous topic - next topic
Which speedo gear
what speedo gear would i use for this combo- rear end gear ratio 5.13, c5 transmission, rims i am going to use are 16' dont know what size tire yet?
Which speedo gear
Quote from: blackcougar71;170348
:evilgrin: 5.13 gear? :evilgrin:  that's enough gear to rotate the earth! :evilgrin:
Which speedo gear
When you're running a car with those gears,do you really NEEEEEEED a speedo???
Which speedo gear
yeah because my cougar that is going to have those gears in it is going to be my daily driver. so a speedo is needed around city streets. then my other car when i get it is a 85 turbocoupe to be a beast on the street/track just like my cougar. so is there a speedo gear for my cougar setup?
Which speedo gear
There is no gear that will even be remotely close for 5.13 cogs...
In the old days they had adapters(a small gear box) that mounted into the transmission and the cable(with gear) went into the adapter... By juggling gears in each you could come up with about any combo imaginable...
That much gear on a C5 is going to get real old in a BIG hurry... Be like driving in second gear...
Which speedo gear
What would I use?
275/60-15 on 15" rims, c4, 3:50 rear gear.
 I think I got a purple gear in there now. I know it off.
:birdsmily:
Which speedo gear
then what about 4.56 gears for my rear end?
Which speedo gear
How about 4:10s tops for the street and even that is to much gear!!
3.73's would still be high for a 3speed but would be much closer with a 23tooth.
Which speedo gear
Do they even make a 5.13 8.8" ring gear?
Which speedo gear
yes
Which speedo gear
8.8 with 5.13s are dirt cheap like $100-300 on ebay i seen them there a few month ago.
Which speedo gear
Quote from: gumby;171084
yes
Really? Wow. It be hell to drive that on the street:toilet:
