Topic: 5.0 Mass Air conversion on 2.3 turbo? (Read 4565 times) previous topic - next topic
I bought this plug for my 5.0 mass air meter for my turbo 2.3 but I'm not sure which wires on the plug go to which wires on the factory wiring. Can anyone help?
What other bits do you have?  You're not just going to plug that in in place of the VAM and have it work.
I also have everything I need to upgrade to a 5.0 throttle body but need to have my intake port matched and I’ve got 46lb injectors, a new fuel rail (OEM), and an adjustable fuel pressure regulator. But I want to put all that on together and like I said I need to port match my intake manifold.
Quote from: JoeNoble;162379
What else do I need?
Some way to convert the signal from the MAF into something the turbo ECU can even use.  They are not the same.
If you look at the wiring diagram for a car with a MAF and a car with a VAM they are totally different.  Its not as simple as changing the connector.  A MAF is treated as a stand alone sensor, a VAM shares wires with other sensors.
Quote from: Chuck W;162410
So basicaly I need to what? Upgrade my ECU?
You need to research. The info is all over TurboFord.org
Quote from: Tbird232ci;162424
Has noone on this forum done a 5.0 mass air conversion on a 2.3 turbo?
Quote from: JoeNoble;162425
I did one, but I included the 5.0 as well... :D
AFIK no one here has done such a mod...
Quote from: TurboCoupe50;162429
AFIK?
As Far as I Know.
you will need a moates j3 adapter and someone to burn you a chip with the maf  tables.
That sounds nice and expensive. Thanks bro.
Are there any mods for the ford 2.3 that don't require ecu modification?
I was told as long as the mass air meter came off another turbo engine that it'll work but my question is were there any turbo fords that came with a flow through maf similar to the 5.0 maf? I found a few on ebay that say they're probe or merker turbo mass air's but can't tell from the pics if they're flow through’s.
