Topic: I did it again... (Read 2506 times) previous topic - next topic
I did it again...
Blew up another intercooler on my way to the track today:
And due to this I decided to uh coochfoot it around the track today and got knocked out right away. Yeah, it's by a truck, but the guy in the truck is also a pit manager there and I'm sure has probably driven the track a bunch of times. I've never driven an oval and the turbo coupe has been far from nice lately so I used it as a learning experience, didn't wanna blow up twice in 1 day.
So anyway, here's me getting my butt whooped by a truck in an oval ;)
http://media.putfile.com/062407Bird
I did it again...
Looks like someone needs a Blow off Valve.
I did it again...
Was he calling it a "pickamatruck"???  Lol silly announcer.  Anyhow, that's cool that you have an oval track, I'm not sure if we do or not.  Must of been fun doing even if you did win though.
I did it again...
Quote from: crystal;156519
Looks like you need to swap to an intercooler that is fully welded.those apear to have spot welds and silicone holding them together.
I did it again...
I’m curious to hear what your plan is to solve that Crystal. Obviously ya can’t just keep throwing new intercoolers in there.
I have never dealt with a turbo before but I noticed right away the same side is coming apart; my first thought was to strap it somehow. But that was before I read the other two guys suggestions..
Blow off Valve
And
Fully Welded
Both sound like possibilities, but a valve sounds like a loss of potential power?
p.s.
Then again, maybe this just goes to show ya that Daboss351 was right!
Lol, ok that was wrong, sorry but I really crack me up sometimes!
I did it again...
that can be repaired obviously.  It came apart where it was assmebled.
Id torch and solder it after i cleaned up the mating surfaces.  you might consider getting it brazed or do that yourself with some poweder flux and some thin brass rods.
solder might do but fixing it probably would be better cause whoever does the fix will see the weak link and do it up better.
thats a lot of presure nonetheless.
I did it again...
I'm sure a fully welded setup wouldn't be a problem for Crystal.:D
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
I did it again...
Yeah... if by any chance you dont...oh i dunno, FEEL like messing with it, I could take it off your hands, if youd like :)
I did it again...
what kind of intercooler are you running, and is that a front mount set up?
yea it broke but you had fun right? thats all that matters
and jim just drop it
I did it again...
That is an 80's Ford Aftermarket FMIC setup. They're siliconed together and then riveted. The one I blew up yesterday ripped the rivets clean through the sides of the aluminum actually. I think I'm going to clean that one up and TIG the whole thing together to see what happens. The core itself seems a bit too delicate to be running a torch right next to it to braze it.
I did it again...
Go with a bypass valve rather than a blow-off valve.
Looks like you're having fun with it, at least.
I did it again...
BPV FTW!!! I have a Forge BPV and I have very minor driveability issues. It's not quiet either. Especially at higher boost levels.
How much boost where your running? And to think I almost paid a nice sum of money for one of those setups.
I did it again...
bpv or bov, it doesn't matter.  My bailey bov sounds schweet and I don't have any issues.
I did it again...
Quote from: stuntmannick;156652
bpv or bov, it doesn't matter.........
........as long as you get a proper BOV for a metered system. i run a Bailey BOV as well w/zero driveability issues
I did it again...
You're going to have to explain this one to me.  I'm dumping metered air (maf) to the atmosphere with no issues.
