Topic: Trans Question (Read 1637 times) previous topic - next topic
Trans Question
[COLOR="Blue"]When a transmission "burns up" because the T.V. cable was not attached, what would need to be replaced? Will a Master Overhaul kit be required? Don't know much about transmissions...[/COLOR]
Trans Question
I also would like to know the answer to that question, if the parts are reasonable i may reconsider building an AOD
Current-
87 Cougar
88 Crown Vic LTD
84 Yamaha Xt600
previous cars -
1990 Dodge Daytona -
1990 Geo Prizm -
1987 Honda Accord - 140mph wonder? Rally ready..... K.I.A. at WOT due to massive head failure. Still had the best paint-job EVER...
1998 Suzuki Sidekick 4D -
1969 Falcon Futura w/ Sports Coupe option (now go try and find that? And if you do tell me where it is!!)
The Cougar will never be for sale, Only up for trade on a 68,69 Falcon 2D.
Trans Question
I'm not an AOD expert, but I believe the TV cable regulates fluid pressure, and when it is disconnected the pressure goes way down. With the low pressure the clutches and bands don't "clamp" tight enough and they slip, causing them to wear out, or "burn up". So, while I'm pulling this out of my ass, at least it's a somewhat educated ass-pulling: The clutches and bands burn up.
Trans Question
If your puttin HP into it theres a lot more than a big kit.
My torqe converter alone cost me 800.
Trans Question
Carmen is correct with his ass pullin' :hick: (Just don't sniff the answer)...:rollin: :rollin: :rollin:
Mainly it's the direct clutch(for 3rd gear) and the O/D band that gets toasted...
Trans Question
Usualy it get the o.d. band. Sometimes the reverse drum (very rarely). But a master kit as long as it comes with bands should do it.
Trans Question
Master overhaul will do it, & ALWAYS put in a new or refurbished torque converter at over haul-too many good reasons why to list. And yes it's the internal friction materials that "burn up". Are you considering doing the rebuild yourself?
