Topic: Layla Runs! Behold the almighty 2.3T! (ALL NEW pics Page 9, A-pillar gauges and trim) (Read 11005 times) previous topic - next topic
Reply #45
.... its nice here thats why i asked o well money is waiting for when you get them out
Reply #46
Quote from: Aerobird Motorsports;152046
Actually, I have HARD data that says otherwise. ;)
I spent a WEEK with laser testers and that IC, and I tell you there's NO heat soak on my car unless it's sitting idle for longer then 3 minutes. Nobody wants to believe me until I make them touch it with their hands after a drive. But hey, I don't have to convince anybody. I know it works, and that's all that matters.
I didnt have to spend a week, i drove in moderate traffic and traffic lights, met up with a couple friends, popped my hood, and my intercooler was almost hot to the touch. Dont need a laser tester to prove that.
And i also have an SC50 with a Bobs log...
Reply #47
Quote from: Tbird232ci;152278
Throw a fan on that B! :D
Why do all of us TFers still have that dirty old cam bolt on the shiny new cam gear. I wanted to clean mine but I installed mine via the shortcut way.
Looking good AM! But why are you hatin on the 3G? lol. :P
Reply #48
Im not going to bother, the car will be gone in a month or so anyways ;)
Reply #49
Quote from: Tbird232ci;152302
I know. Tis was a kidding. :)
Reply #50
I coated my ported E6, turbine housing, and down elbow. Plus I've removed all of my A/C and underhood liner and rubber IC seal. The IC is painted with heat paint as well. I did all of my testing in moderate traffic in WA state with a $1200 laser temp gun borrowed from the US Coast Guard to measure temps on turbo's in boats. I did a LOT of adjusting, tuning, and "messing with" the IC to get some #'s.
Heat soak is near immediate in heavy traffic, stop-and-go, and hot idle. Given a "cool-down" at the end of a run (for oil pen 15ing) however seems to last 2-3 minutes as long as ambient is ~65* or less.
WATER temp had the biggest impact on IC temp (outside of the coatings). A 160* Tstat does WONDERS for underhood temps and detonation.
Granted, it's not perfect. But compared to massive boost loss it's pretty good. I still think air/water is the way to go, especially on a daily driver.
The bolt bothers me too :hick:
Reply #51
so is it ognna stop raining soon i hate to keep asking but i need those lines lol. i want to be able to actually let the car RUN for a bit, without dumping my 3 dollars a gallon gas everywhere!
Reply #52
I can't control the weather :( But I have Fri/Sat/Sun/Mon off so stripping will commence.
Reply #53
Due to wheelbase difference's Tbird lines will not fit a Lincoln.  You will have to cut and splice them if you didn't already know this.
Reply #54
its nylon line just try them up out of the way, if not ill find a way to make them work. its better then 7 inches of rubber line on metal line
and aero might as well pm me about payment and all that so i can set it up to get it out to you asap, once you get them out and ready to go. hell ill send the money early if you want, i trust ya!
Reply #55
Smoking issue is GONE. Prototype MaxPSI oil return line kinked. A new stock-length solved the issue permanently. Boost turned up to 15# and I'm living the good life!
Reply #56
sweet, never had a chance to get the cash out, so ill just wait till you get shipping set up. pulled them yet?
Reply #57
Bunch-O-Pics time :D
These are all from today as I did my errands and went to a final.
These 3 are at the bank of the Cowlitz River by my house.
Reply #58
Here's a pic of the engine running ;)
And 2 "experimental" ones for ideas.
Reply #59
These 3 are from by my gym. I started going again because I need a diet if the car is to go fast! :hick:
