Topic: Layla Runs! Behold the almighty 2.3T! (ALL NEW pics Page 9, A-pillar gauges and trim) (Read 11074 times) previous topic - next topic
Not only is the exterior bone stock, it's ugly :hick:
Clearcoat peel, the rear bumper trim is missing, the wheels suck, o h yeah, she's a sleeper. ;)
That will all be changing slowly but surely. Eventually she'll look nice (still stock) but lowered on 03 Cobra Anny wheels.
I personally think just making it look bone stock, yet nice and clean would be perfect.  But I guess I'm just a hypocrite cause my car will eventually be lowered on a set of nice wheels (Bullitts or Keystones or somethin) too, so yeah.  These cars just beg for it.
I also went on a 5-mile drive today. VERY therapeutic BTW. I *tried* to take a video, but steering, videoing, and shifting is harder in Layla then in the truck :D . The T-stat housing ended up having a hole in it, so I had to use a spare. Now there's no leaks of any fluids! (Gotta be a TC first...:hick: ) So far, so good. I still have my tinkering to do, but it's apparent now that I need to clean out the IAC, adjust the TPS and idle screw, and play with the fuel pressure, boost, and both distributor and cam timing. She's at 10 psi now, and from 4,000-6,500 pulls like CRAZY. Once break-in is done, I'll turn up the wick.
BTW, the only "casualty" from sitting for 6 months, is the left turn blinker, not bad huh?
 that left turn blinker!  :beatyoass:
Quote from: Aerobird Motorsports;151631
ever heard of using a passenger to hold a camera? :hick:
1979 Ford Fairmont
[/B]
Quote from: 32VFoxBird;151338
this is your "built" motor?
With an Esslinger head and a turbo that size, I'd hope so. ;)
I'd love to have that under my hood, man. Very nice.
Quote from: 32VFoxBird;151643
Nobody's brave enough to ride in it yet :hick: Spending 6 months on jackstands makes people leery...
Quote from: oldraven;151695
Thank you. I have another 2.3T in the garage that's going to be even more wild... :evilgrin:
DOHC???? for the next one??
All that and still no FMIC?
Why?
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Quote from: Red_LX;151786
Why?
Which would have solved the VC clearance issue with a rotated upper intake.
hope its not raining where you are i want you to pull those lines tomorrow. its pouring here!
No DOHC, but Aluminum and giganto Inconel exhaust valves ;)
FMIC's are for monkey-see, monkey-do's and all out race-cars. I have an immeasurable amount of boost loss, and laser temp readings show over 75% IC efficiency at speeds of ~45 MPH. Why lose 2-3psi and plumb a nightmare for maybe 5% more efficiency? Unless I rotated the intake the charge pipe would just get heated back up anyways. The ONLY thing I'll consider is a water/air setup in the factory location.
It's raining :(
10 more miles today. Even got a fresh tank of gas! I also installed the V8 TBird radiator overflow bottle (passenger front of radiator) to make room for the oil catch can. Fixed about 7-8 vacuum leaks, and removed the head lifting eye for the oil control plumbing.
Did a big smokey burnout too ;)
so no fuel lines tomorrow i take it then
Wednesday son, Wednesday. Not Tuesday. And it's supposed to rain all week. Can't push a non-running 5.0 Bird in mud, it doesn't roll.
But as soon as I get it over here, I'll strip the fuel lines for you. ;)
