Topic: Ram Air Fender (updated! Pics-Pg3) (Read 6615 times) previous topic - next topic
I decided to add a custom touch to my fender since I had it off to do the body work anyways.  I figure this will make it a one of a kind deal.  Added one of my TC replica scoops to it.  turned out pretty good me thinks...  Still gotta do the putty work but almost all the metal work is done.  now I just gotta build a box behind it to make it functional which will happen tomorrow.  The driverside may get the samething, as I have a few things that need lots of air, to go in behind there, ;)
dude that is f'n badness.
louie  :birdsmily:
My famous last words:
I would really like to see this one picture by picture followed through RJ.  Thats completely off the wall and really cool.
It won't suck in a lot of water will it?Those things worry me.It looks awesome.I'd add another to the other fender,just to even things up.Maybe not functional,but it would balance out the front of the car.
What are you trying to cool? Those scoops don't pull in alot of air unless you are moving at higher speeds. Looks good so far. I wanna see the finished pics.
Quote from: vinnietbird;151005
Thanks guys.  A little water (as in, what ANY OF the ram air systems out there, will/could suck up under normal driving conditions) wont hurt your motor, unless of course you try driving under water.  as for the none functional part?  I think this will make it functional on the driverside as well dont you? ;):
Hence the term "Ram Air".  not to be too much of a dick.  But, I have been seriously working on cars and building them up since I was 16, I know how these scoops work.  look at where the stock intake tract is on these cars, now think of the benifits of a cooler, denser intake charge with out all the extra plumbing from a March ram air kit.  Plus I did it just to be a little different then the guy beside me at a car show.
TT!!!! sweet!!!
Turbo? ;)
not just "A" turbo, but twins.
Quote from: 1WLD BRD;151014
Two is better than one :D
Ya going to rebuild the bottom end or just run it till it blows?
thats why i said TT
actually since It needs a rebuild anyways, It is cheaper to rebuild a 351W then it is the HO, so that will go in instead.
OH MY GOD! TT!!! WOWEEE
Man, you guys need to get out some.
The fender idea is pretty wild, i personally wouldnt do it, but it think its definatly something new. I want to see it with paint.
Quote from: 1WLD BRD;151020
Really? Why?
"Plus I did it just to be a little different then the guy beside me at a car show".
That would be me LOL.
Dam ron i don't think your gonna be ready by next wednesday,unless you go hardcore this weekend and "get er done".
Not a bad idea though,if you run a cold air setup through the hole in the inner fender wall where the power pipe goes on mine it would be easy to make it work.
