Topic: gtp heads (Read 1217 times) previous topic - next topic
gtp heads
will gtp heads have any valve/piston clearance problems with SO pistons?
gtp heads
Most likely you'll need valve reliefs.
gtp heads
like magic,,, if you click that button called search,,
then type in this very thread title,,"gtp heads",, the solutions are there.
http://www.foxtbirdcougarforums.com/search.php?searchid=210577
lots of info in my diy link as well above my sig
gtp heads
Quote from: vinnietbird;144764
Yep
gtp heads
what are valve reliefs?
gtp heads
cuts in the pistons to allow the valves to travel out without hitting the pistons. Last thing you want is your piston nailing the valves!
