Topic: stock rear ends (Read 4269 times) previous topic - next topic
stock rear ends
what car came with a traction lok rear from the factory that will fit in a 84 cougar?
stock rear ends
HEY,I have a 7.5 3.45 geared traction Lock rear you can HAVE for free if you want to come and pick it up ( I'm going to use the 8.8 Stang rear I bought).This rear never gave me any problems at all.As a matter of fact,it's the rear that was in Old Blue in the burnout shot in the banner above.I have to make room in the garage,and it really needs to go.I'm down here in Ardmore (a little over an hour drive).It'll bolt right in.It needs the brakes,brake lines and wheel cylinders(which you can use from your current rear)and that's it.If you are interested,let me know and I'll get directions for you.
stock rear ends
i will take it. can yu save it till the end of may? because i dont have the time cause of school and work.
stock rear ends
No worries.It'll sit until you're ready for it.I amy have the quad shocks from my parts car if you need them.You'll have to come up with the brackets,mine were welded on.I'll try to snag some brackets at the boneyard.keep me posted when you're ready.I'll be in California from May 29 to June 5th.
stock rear ends
I will come and take it off your hands today, or tommorow, whenever.  I am in Norman.
Thanks
stock rear ends
hey vinnie  do you still have that trac lok rear end?
stock rear ends
I do still have it.
stock rear ends
hey vinnie what is your address? i will come and pick up that rear end august 25 or september 1. if that ok with you
stock rear ends
Both of the Traction Lock rears are gone.I hauled them to the s yard two weeks ago and sold them with the rest of my s pile for $$.I was running out of space in a big way.There's a Turbo Coupoe with a disc rear at D&H auto salvage here in Ardmore.I don't know how much he'd charge,though.There's also two of them in Durant Oklahoma at one of the yards.I can't remember the name,but it's on 9th street.Information can find the number if you need to call.Just tell them a  salvage yard on 9th.It's J&H or something like that.I kept the Traction Lock rears  as long as I could.Sorry.I have a 2.73 TL rear in my Bird I'll be pulling out soon.I don't know if that will help you or not.
stock rear ends
do you know where i can get a 7.5 traction lock with 5.13 gears both together or at the same place?
stock rear ends
5.13 gears?Wow,that's a steep order.I have no idea where one with those specs would be.
stock rear ends
so far the biggest i can find for a 7.5 is 4.56.  i'll keep digging.
edit*  richmond gear part # 6903481
that's the ring and pinion that you need.
then you still need the install kit.  part # 8310451
just find a decent 7.5 rear end and you're set.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
stock rear ends
i found tons of gear ratios for the 7.5 rear ends for $200 or less on ebay under mustang 7.5 and the biggest gears for a 7.5 that i have seen is 5.13. i just need a traction lock complete rear end basically then put my 5.13s in . what is the differences between the auburn and track lock.
stock rear ends
I don't know.If you can wait just a few weeks,you can have my TL rear that's in my car now.It has 2.73's in it,but it is in great shape,then,you can put your gears in it.No charge if you can wait.I'll let you know when I swap mine.
stock rear ends
If you're not interested,it's going to the syard.
