Topic: stock rear ends (Read 4292 times) previous topic - next topic
stock rear ends
i am not ready for installation of a rear end anyway for at least a couple of months till i get the complete suspension kit that i am buying from roush and you can take your time i am not in a big hurry and this time i will make time to pick it up so it out of your way.
stock rear ends
was your rear end swap successful vinnie?
stock rear ends
The 8.8 hasn't gone in yet.It's still sitting on jack stands in the garage.It'll be an easy swap,just bolt it in and bleed the brakes.I just haven't had time.We (my budy and i) decided to install the rear when we do the cam,heads,and timing gear swap.While the car is cooling off,we'll replace the rear with the 8.8,then,the 7.5 will find a new home somewhere.The other 3 TL 7.5 rears I had went to the s yard.Two had 3.45 gears,one had 2.73 gears.I tried to give them away and noone would take them.Now,I suppose they've been chewed up into little bits and have been recycled into railroad track or something.The TL coming out will be free if someone wants it when i do the swap.TL with 2.73 gears.
stock rear ends
when you have the TL out of your car tell me a week a head then i will pick it up i need it bad...
stock rear ends
Are you sure this time?LOL.
stock rear ends
i am super sure i even have it arranged so you just have to tell me the day and i will be there.
stock rear ends
When it's ready,I'll hold it for you for a week.Then,if you don't make it,off to the s yard.I need all the garage space I can have.I'll let you know the day I pull it.
stock rear ends
Quote from: blackcougar71;168865
Good luck buying Roush suspension parts that fit a Thunderbird.
stock rear ends
the suspension parts i'm buying are roush made suspension parts for fox body cougar and thunderbird during the 80's. the parts i planning on was put on nascar and different race cars.
