Topic: help (Read 5050 times) previous topic - next topic
help
87 3.8 bird rear end size not sure want 5 kugs now need right size??? help plase
help
Slow down son!  Re read what you posted.. Not a bit of it makes any sense!
help
You've got a 7.5" in that sweet ride. That don't help none though. You want some axles from a 94-98 'Tang. Make sure they don't have the ABS rings.
least i know the size now
well i figured that some one would anwser and let me know least i was hoping. what size rear end would it b from a stang for those years and would it bolt right up
help
Claude would know!
help
that would be who lol
help
Quote from: willywags05;137198
The v6 stang bangers would have the 7.5 and its axles would fit fine.  Aside from the brakes the stang rear would bolt in without a hitch.
help
from a 94 to 98 stang rear end bolt right up and what size is it
help
Quote from: CougarSE;137203
:beatyoass:.
help
so a 7.5 rear with 5 lug will work  for my 87 bird
help
:mad:.
help
That makes 3 of us.
help
ok here what i am trying to do make my 87 tbird with a v6 4 bolt to a 5 bolt
help
*BUZZ*!!!!!!
Try again.
86-88 Tbird/Cougar 7.5's will not work with the Mustang axles....
You can swap the entire rear axle assy from the SN-95 Mustang, brakes, housing and all if you like and have the same width axle  to axle , but the axles alone will not swap into the wider 87 7.5 housing.
