Topic: help (Read 4683 times) previous topic - next topic
help
i understand know thanks
help
just get a rear axle assy from sn-95 stang and bolt it up
help
Quote from: Chuck W;137216
*BUZZ*!!!!!!
Try again.
86-88 Tbird/Cougar 7.5's will not work with the Mustang axles....
You can swap the entire rear axle assy from the SN-95 Mustang if you like and have the same width axle  to axle , but the axles will not swap into the wider 87 7.5 housing.
That is news to me. :confused:
Bearing areas don't match up?
help
maybe i dont get it hell i dont know
help
Quote from: JeremyB;137219
IIRC that's one of the issues covered in the threads that touched on this whole issue.  The 3/4" may not be an problem, but most likely it is.
The 86-88 Tbird 7.5 housing are wider....and thus the bearings are in a different spot than the  others.
willywags....there is a search feature on this board.....it works....
help
I thought that the axle housing of the sn95 was the same width as the 86-88.  Infact i slid my sn95 axles into my old 88 housing and they seem to fit fine...
ERER I ARE CORNFUSED..
help
shiznit, I JUST REALISED that your right in my backyard. Sorry,
/end spaz attack
help
Quote from: 84 Fila;137229
/end spaz attack
Now I understand....
help
Nope....the 86-88 Tbird 7.5 housings are 3/4" wider per side than the Mustang and early Tbird 7.5's and the 8.8's.
The axles will slide in....
help
Understand what Cluade?
help
Quote from: Chuck W;137234
So the fox stang and sn95 housing is the same?
help
LOOK HERE
Yes, the 79-98 Mustang 7.5 and 8.8, the 83-85Tbird 7.5 and 87-88TC 8.8 housings are all the same width...
The 86-88 Tbird/Cougar 7.5's are wider....
help
so dropping a ho 302 in and and tranny th axle will need changed right
