Topic: mustang engine parts!! (Read 2123 times) previous topic - next topic
im looking for MAF harness and computer, heads, intake, really anything that will work with the stock SO block and pistons.
I have a set of e7te heads,upper ho intake,throttlebody and 19lb injectors if your interested but i live in ontario canada so shipping might be a little high as thoses heads are heavy,all parts had about 90k on them and work great.
yeah, those heads might be abit to pricey, but i would love the HO upper intake manifold though!
Have you checked E-bay?All I have left from my Mustang parts are the factory aluminum valve covers.Ifixyawata got all of my H.O pieces..
I have a set of E7 heads, H.O. upper intake ('87-'93), TB ('87-'93), MAF ('90-'93  & '94-up styles), and stock Mustang GT cam ('94 w40k miles).
Ray
cool. how much for the MAF unit?
$25 shipped
is it just the sensor, or what? what comes in the package?
and is your upper intake manifold have all the niples for hoses?
If the H.O upper doesn't have the vacuum hose tree on it,I have one for it.
The MAF is just the sensor and housing, no mounting bracket or wiring. The upper intake has the main vacuum tree attached. It is missing the T that mounts on the outer edge.
will the tree from the SO work on the HO? amd isnt it missing the right bottum plug?
AFAIK the parts from the SO will work on the HO intake no problem. The "bottom right plug" was a vacuum T that I was talking about missing.
oo what about the hole on the very bottum left?
Just to be sure we're on the same page...
Red arrow: Missing vacuum fitting
Blue Circle: Pipe plug
Yellow Circle: Missing vacuum T
Parts from your SO intake should work, but someone else can varify that. I'm not 100% sure.
