Topic: remote replacement (Read 1299 times) previous topic - next topic
remote replacement
I'am down to 1 remote and the case is cracked .The number on the back is goh m24 does anybody where to get a replacement?It's for 97 :cougarsmily: with a v6
remote replacement
Your local ford dealer They can program it also
remote replacement
Check ebay or do a google search for key fobs or something similar. I did this after we purchased our explorer because we did get any remotes with it. There is a place (do remember the name) that sells the geuine Ford remotes.
Our web page
02 Explorer XLT 4.0L
04 F150 FX4 Supercrew 5.4L
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
remote replacement
Ive got a couple new ones I bought and never used, I will check and see if they are the same.  You can program them yourself.
remote replacement
Thanks all.I found a place online 50 bucks .
remote replacement
Sam I sent you a pm
remote replacement
I need some input.I brought 2 new remotes and they gave me detailed instructions.
I can't get the to alarm cycle to program the new remotes.There a led light on the dash it says hold the light for 20 seconds to start the process any ideas?
remote replacement
I can't speak about keyfobs but I've programmed enough home remotes to realize that although the self program functions might be easier or more accurate, I  question accurate, but doing it manually is by far faster! It might take a little practice to get the process down. Push button 15 sec look closely remote blinks then go to next instruction step. Mess up, remove battery, start over. It's a process.
