Topic: Center dash mods (Read 7276 times) previous topic - next topic
Center dash mods
There are a couple things about my 86TC I dont like.  The biggest one is the lack of cup holders.
Heres my plan:
Install a Taurus temperature control in the top slot.
Install a aftermarket stereo in the oem temperature slot.
Install a Taurus coin/cupholder in the current stereo slot.
Delete the current cubbyhole.
I can make this plan work as long as there is enough room behind the current temperature slot to fit the stereo.  The stereo will be alittle low, but I have a remote and its a minor inconvience to gain a cupholder.
Can anyone who has had the dash apart tell me how deep the hole is behind the temperature slot?
Center dash mods
It's as deep as the current radio slot. Only the top space is cramped due to the HVAC vents...everything else is as "normal" as you get on these cars.
By the way...what you plan to do...I did in 1992. ;)
Center dash mods
what were they thinking not giving us cupholders. even mustangs got em, right?
Center dash mods
How hard is it to add the Taurus cup holder?I've had one for years and still haven't even attempted to swap it in.
Center dash mods
why is it we all need cup holders? i dont... if i dont have a passenger... i buckle my drinks into the passenger seat....... if i got a passenger they become my cup holder lol.  good luck thats all i can say
Center dash mods
In 1985-88 dashes, the bottom 3 holes are theoretically the standard 1-DIN size. But in typical Ford fashion, nothing fits exactly so. The Taurus cupholder was designed for the Ford dashes made after ours, which requires the U-shaped removal tools to pinch in the side clips, thus allowing removal without any screwdrivers. It's a really nice setup but unfortunately it's not practical to backwards-adapt that design to our dashes. The hole in the radio panel slot (wherever the Taurus panel is to go) has to be trimmed and straightened, top and bottom and at least on one side, and this will allow the Taurus cupholder panel to slide in and the clips will catch. That's about the only way I ever got it to work. This also means there's no brace in the back of the panel to hold it up...but I never had any problems with it. It always seemed to be sturdy enough just being held in by the clips on the radio panel.
Center dash mods
Eric,do you have a pic?This sounds interesting.
Center dash mods
i hate those stupid u shaped tools, i just use coathangers
Center dash mods
I can't find pix...it's been 15 years, I'm going by memory on this. But certainly there are people here that have done it and took photos.
Center dash mods
I didnt figure it was a new mod.  I want a cup holder so Im doing it.  Eyeballing it, it looked like the radio slot was the best bet for minimal dash tpuppies.  I figure that I will have to fab a support to help hold it up.
When placing a drink in the holder, the front should drop down, causing the back to go up, so it will need to be braced on the top, not on the bottom.
Anyway, I will see how it works out.
Why isnt this a mod in Cool Cats Tech Center?
Center dash mods
It used to be, a long time ago. But I've had a change of heart about cupholders since then. ;)
Just FYI...with the cupholder extended and a cup in the tray...there's not enough weight in the assembly to really move it up or down that much at all. It doesn't need bracing. I only mentioned bracing to try and keep it away from, say, a radio that may get hot and potentially melt the plastic.
Center dash mods
Thanks for the info.  I for one love cup holders.  Its one of the little things that makes life more pleasent.
I was considering installing a 05+ double din CD player, but I dont want to monkey with the bezel to make it work, maybe later, I picked up a spare for just such a project.
I have a CD player that I think will fit the oem climate control slot without mods, so Im going that route.
1st is to remove the carpet for a re-dye and install sound deadner and run stereo wires.
Center dash mods
I don't need cup holders being that I don't allow food or drinks in my T-bird for fear of spillage.
Center dash mods
thats way sealed bottles are for!
Center dash mods
Eric has it right. Cupholders are for cooches.
