Topic: cfi to sfi (Read 2852 times) previous topic - next topic
cfi to sfi
You've got an AOD, and yes, it'll bolt to either a 5.0 OR 3.8
For the work involved changing to SEFI, it'd be  more cost efficient  to swap in an EFI 5.0, more power, equal-or-better fuel economy, better exhaust sound, and on and on.
Then you have the head gasket problems of the 3.8 to consider, as well.
I think we ALL know the longevity of well maintained 5.0-the one in my 92 F-150 is still runnign strong at 290,000 miles, and it has never been pulled out, just the basic maintenance stuff, water pumps, fuel pump, O2 sensor, and the like.
It has sure as hell lasted longer than the 3.8 in my Tbird.
But, if you want to stay with the 3.8, it can be done, and has been before. Good luck!
cfi to sfi
The motor in the CVIP is a 5.0 EFI. It has somewhere close to 300,xxx miles on it too. Still strong. If you're going to do the work, i agree that a 5.0 may be eaiser. May we ask why you wana rid of CFI?
cfi to sfi
Correct me if I'm wrong, but don't the injectors on a SFI go into the heads?  That means at least a head change, along with manifold, sensors, ETC.  Put a V8 in.  Good luck,  Fred
cfi to sfi
I thought they went on a fuel rail but I may be wrong
cfi to sfi
Yeah, I think Fred is right about the injectors.
cfi to sfi
Yeah, I'm unsure. I've never acutally seen a 5.0 or done that much work to it. Only normal stuff to them, like routine maintnence
cfi to sfi
i wanted to get rid of my cfi because i thought sefi would be much better. but from wat it turns out sefi wouldnt help my car very much in horsepower.
cfi to sfi
For an easy fix, swap a 5.0 CFI onto it. The CFI body itself will help. I have one if need
cfi to sfi
Getting more power into a 3.8L can be about as expensive as the cost to get even more power from a 5.0L.  Using the 5.0 CFI probably won't do much but dump more fuel in and decrease gas mileage.  More fuel without more air (heads, exhaust) won't do much to benefit power.
cfi to sfi
You could to some the CFI mods listed in scott's thread to it to get a few more. Again a 5.0 CFI will get ya a few, but not enough to be worth it IMO.
