Topic: Step 1: Suspension. (Read 18482 times) previous topic - next topic
Step 1: Suspension.
Reply #75
I went and got autozone mounts and they worked fine on the 88.
Step 1: Suspension.
Reply #76
I used washers no problem,5/8 I think.
Step 1: Suspension.
Reply #77
I've made this whole 11" brake thing way more complicated than it needs to be... sheesh.
Step 1: Suspension.
Reply #78
I bought them mounts pictured they wouldn't work for me,they didn't seem to tighten enough.Used my old ones,still have them if anybody wants them.
Step 1: Suspension.
Reply #79
My whole big mistake was buying Mustang struts.  I forgot to mention that the lady at the parts store belittled and scolded me when I went to return the mounts.  "Why would you buy the incorrect parts?  What are you trying to do, exactly?"  When I explained to her that the T-bird and Mustang shared a chassis/platform, she shook her head and asked her co-workers and they all disagreed.  It's unfortunate the first guy I spoke with wasn't there.  He was kind enough to punch up any fox car I could think of & compare part numbers.  Even pulled and opened the Mustang strut so I could show him the issue I was having with the strut mount.... oh well.  I'm done with that store.
Step 1: Suspension.
Reply #80
Advance Auto FTL on this one. So all you have to do is get 88 struts and problem solved?
Step 1: Suspension.
Reply #81
Alright, now that CJ's come and gone and I'm regretting not having a car there, I'm motivated to get this t-bird done before the winter descends upon us.
Gonna go ahead and revive this thread with another stupid question or two:
Which of the ports on the steering rack is the pressure and which is the return? I didn't pay attention when I took the lines off of the old one.  Also, it looks like the short section of return hardline doesn't have the o-ring or a provision for one like the new pressure line does.  This normal?  I've got late-night motivation to get some shiznit done so I'm gonna go out and crack on it right now.
Step 1: Suspension.
Reply #82
Nevermind my last post.  I went out and tinkered with it and I realized that the pressure and return are different sizes, so it's idiot-proof in that respect.  Also found out that there were actually o-rings hidden inside, too and I got those replaced, with the exception of the rack-side pressure line.  The new line came with 3 o-rings, two small ones and one much larger one.  One of the small ones fits the pump side of the hose, but none of 'em fit the rack-side fitting, so I'm stuck there.
I'm also stuck on the fact that I can't figure out how the **** the short return hardline on the rack is oriented.  I put it on the way I thought it went ended up pointing against and touching the DS strut tower.  THIS is why no one should take a car apart, then try and put it back together FIVE MONTHS later.
Step 1: Suspension.
Reply #83
My retun line pints almost straight out.Good luck on the car.Now that I FINALLY have everything I need for the cam swap and mass air conversion,I'm getting a little more motivated myself.Get to it !!!
