Topic: started cleaning up the engine bay (Read 50387 times) previous topic - next topic
Reply #270
im not sure on the height of the dash. the motor weighs roughly 550lbs.
1979 Ford Fairmont
[/B]
Reply #271
I'm really just looking for more of a feel, not a measurement.  For example, how will it be sitting in the seat and driving?  It appears a bit higher, think it'll be wierd to look over?
1988 Thunderbird Turbo Coupe
Reply #272
This might help. Here is a picture comparison from about the same distance and angle. It doesn't look like it's much different height wise.
Brent
:cougarsmily:
One of 1,246 built
Reply #273
yeah, that does help.  It looks a bit higher where the dash arches up, but not much, huh?  1-2" maybe?
Reply #274
Quote from: booksix;203976
The angles aren't exactly the same but it appears to be no more than an inch or two different if it is at all.
Brent
:cougarsmily:
One of 1,246 built
Reply #275
if you draw a line with your eye tangent to the top of the highest point of the dash and over to the mirror trim plate, they look nearly the same height to me.
Reply #276
So, why the talk in earlier posts about no A/C making the dash install easier?
Reply #277
Quote from: booksix;204022
because you have to trim about 3" off the back of it to make the dash fit flush to the windshield. along with tpuppies the steel supports to clear the a-pillars. it is no way a "bolt-in". if you are thinking about doing the swap, i would do a google search to see what everyone else has done to make it fit.
1979 Ford Fairmont
[/B]
Reply #278
Oh yeah, I know it's not a bolt in!  That's what makes it fun!  I'm just wondering what tpuppies the dash has to do with the a/c.  I started a thread in the interior forum about an sn95 dash swap.  Would you mind sharing your personal experience over there?
Reply #279
my guess is ductwork prevents AC, with that much trimmed off.
1987 TC
Reply #280
Awesome work. One word of caution, though: do yourself a favor and take a CLOSE look at the spark plug threading in the heads, especially for plug #3. There have been reports that many of those engines don't have enough thread for the plugs and they sometimes spit the plugs out. An ounce of prevention and all that...
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Reply #281
im gonna need a tall hood!
pic is of a carb im going through mounted on the intake with a N20 plate.
1979 Ford Fairmont
[/B]
Reply #282
Quote from: 32VFoxBird;210979
add the filter... yeah thats tall. How much is it sticking out right now? how much taller is it with the filter?
I just had a vision.... tall cowl+ Fox SVO scoop opened up= greatness! just an idea
Reply #283
Putting headers on that must of been fun!Great job and patience.
Reply #284
Sweet.Keep us posted,and more pics please.
