Topic: started cleaning up the engine bay (Read 50325 times) previous topic - next topic
Reply #285
Quote from: cougar86_89;210993
add the filter... yeah thats tall. How much is it sticking out right now? how much taller is it with the filter?
I just had a vision.... tall cowl+ Fox SVO scoop opened up= greatness! just an idea
actually i was thinking of using the center section from the mach 1 hood, and glassing it onto a stock replacement fiberglass hood with the mach scoop. :D
1979 Ford Fairmont
[/B]
Reply #286
That works even better than I expected.  The body lines match up pretty closely.  It will look great and function well as a bonus.
Reply #287
Are you going to raise up the back of it? I forgot that you had all that stuff. Looks good. totally original. Even if you didnt raise the back up i think it might look ok. Are you going to make a tray for the bottom of the scoop to mount on tha carb? Are you cutting out all of the hood that will be covered by the Mach section?
Reply #288
so many questions!
yes, ill make a bracket for the scoop. yes, ill be cutting a large section out of the hood. and ill have the hood look as close to a original mach as possible. the height of the scoop is going to determine how high the hood is going to be.
1979 Ford Fairmont
[/B]
Reply #289
Quote from: 32VFoxBird;211108
so many questions!
Sorry but I think I might be more excited than you to see it finish! I always wanted to make a cowl hood out of a 96-98 (cant remember what year it was) cobra R hood. I like the way it looks like it steps up twice. I guess now that i look at it more you could trim the front to make it a shorter height after leveling the rear too.
Reply #290
its no problem. ill be excited too, when i find a good fiberglass guy. LOL!
1979 Ford Fairmont
[/B]
Reply #291
Its not too difficult. Bring her up here and I'll do it for you. I love making custom pieces. You should see the hood Im making for my truck. lol now thats a project.
Reply #292
Wow, that sticks out more than I expected!  Is that shaker gonna cut it?
1988 Thunderbird Turbo Coupe
Reply #293
Quote from: booksix;211455
i think so. as long as i get the height of the center section right.
BTW, your interior looks tits, man!
1979 Ford Fairmont
[/B]
Reply #294
Thanks!  Couldn't have done it without your parts (but the pedals were a nightmare, lol), not to mention the all important inspiration!  I had forgotten all about the SN dash swap for the last few years and this thread is actually what got me going.  Gonna start toying with those door panels next.
Anyway, good luck with that hood!  I can't wait to see a shaker on that 'bird.  Gonna be so dope!
Reply #295
another update!
i redid all the brake lines, except the ones that run along the rear axle. those were redone a couple years back. its all 3/16" tubing with a mix of 45* tube nuts and 37* AN fittings. :hick:
one of the pics shows where i had to drill a hole in the strut tower, just so one of the lines could screw onto the MC.
1979 Ford Fairmont
[/B]
Reply #296
more....
1979 Ford Fairmont
[/B]
Reply #297
Fake Shaker :shakehead:
Functional Shaker :headbang:
Please do me one favor so that I don't have nightmares.  Put either some hose (fuel line or vacuum) over those lines where they pass through metal, or add some grommets.
Lookin' good.
__________________
Twin '85 TCs
White/ Grey 2-tone
Reply #298
i spent a good 2 hours getting the length of these hoses cut, so i could get them screwed on. i havent messed with braided hoses in awhile, but ill say this. Jeg's brand hose ends are the EASIEST to work with. i had absolute hell with one XRP fitting.
1979 Ford Fairmont
[/B]
Reply #299
Is it going to be done to make a pass this season do you think?
