Topic: started cleaning up the engine bay (Read 50516 times) previous topic - next topic
Reply #240
he means its making him think about stealing the motor from him grandfathers navigator.
Reply #241
thankyou sir
Reply #242
Quote from: 32VFoxBird;195997
got a few more parts in this week...
jegs brand 8an hose 15ft
assortment of jegs an fittings
jegster universal sump
procomp 140gph fuel pump
Yeah you'll NEED that a sump. The engine in my 88 will stall under full throttle with less than 3/4 of a tank because the gas sloshes away from the fuel pump pick up. Your engine would probably be even better than mine at doing that with a stock tank :hick:
Reply #243
i hope it works out ok. i have a friend that's going to weld it on.
i also have another small update:
i sold me intake and carb........
carb was too big(from what several have told me), and wanted an intake with the water x-over. so i was able to order this the other day:
and i plan on buying a 650 for cheap, and putting a kit in it myself. i also found a trick way to install AN fittings on your hose without cutting the shiznit out of your hands, arms, face, etc. :D
1979 Ford Fairmont
[/B]
Reply #244
Quote from: 32VFoxBird;198688
wrap the braids with tape before you cut them? what you use to cut them makes a big difference too.
Reply #245
Quote from: 32VFoxBird;186179
alrighty....
i got the motor in, and had a few snags. the navi driver side exhaust manifold will not clear the steering shaft. the oil pan rubs the steering rack(still!), and i got the wrong bolts for the flexplate. i wound up having to pull the trans out, so we could get the motor in. (i had 2 friends come over, and they werent coming over to do nothing, LOL!)
im now on the hunt for a manual steering rack, driver side cobra exhaust manifold, and the correct flexplate bolts. then i get to re-stab the 200lbs trans! yay me!
the carb sticks out of the hood by 2" right now. it will be higher once i have the N2O plate and air cleaner on there. i will look into using a "shaker" style hood scoop, as i feel a 6" cowl hood will look ridiculous on this car.
  , straight!!!  Show that motor off!!
Can you get 5.4 stickers for the air cleaner, like they have on the older muscle cars?
I've reread the entire thread with renewed interest, and I can't wait to see this thing done.  Boy, if that 5.4 fits, I know my 400 will.:D
1987 TC
Reply #246
I i got a 650 four barrel holley, i was suppose to trade it to fila but like that would happen. let me know if your interested. Needs a cleaning BAD and more then likely a rebuild.
Reply #247
Quote from: HAVI;198747
I just did the same thing...
Reply #248
new manifold arrived yesterday, and today i took it to have a couple of fittings welded on. ill have it back tomorrow, but then its getting ceramic coated at another place! it will look somewhat polished. i cant wait to see it. it'll take about a week.
1979 Ford Fairmont
[/B]
Reply #249
for the polished look, the intake had to be sanded down to at least 320grit. so i took it too a chrome plating shop and had them do it. they did a good job. the exterior feels like glass.
now i need to get it to the other place for coating. i may go today, if my back stops hurting.
1979 Ford Fairmont
[/B]
Reply #250
since i cant sleep, i decided to pull the timing cover off and paint it to match the cam covers. i also cleaned up the dust everywhere, and took a better pic this time....
1979 Ford Fairmont
[/B]
Reply #251
very sick dude is that the 4.6 or 5.4? i havent check back to see.
Reply #252
very nice!
Reply #253
Quote from: midget28;203253
5.4l from a '02 Navigator
1979 Ford Fairmont
[/B]
Reply #254
are you switching to efi? cause it looks like that intake is drilled for injectors?
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
