Topic: What are you guys using to paint wheels? (Read 6105 times) previous topic - next topic
I've got a set of wheels I want to do up in a satin black.  The budget isn't going to allow for stripping/powdercoating, so I'm just going to clean/scuff/paint them.
I suppose the "std" Krylon or Rustoleum stuff would be ok.  I've had real good luck with the high temp (500*) engine paint and thought about using that instead.  I was going to then bake them afterwards.
Thoughts?
Dupli-Color Wheel Paint is THE bomb. $5.99/can, comes in about 8 different colors (white, argent, gunmetal, matte black, gloss black, bronze, and dark argent). Resistant to brake dust, looks GREAT. I restored some Magnum 500's with it and I have some Bronze for the GTO and some Gunmetal for Layla if it ever stops freaking raining!
Who carries that?
Autozone and Advance both also carry that stuff...
Been thinking about trying out some of that myself. Would like to paint up my wheels with graphite.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Looks like I'll have to give the satin black a try.
Agreed,used it to paint my ponies and it works awesome.
Chuck, I use engine paint on just about every part on my car. I've had good luck with that stuff.
Alan
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
the dulicolor paint works great, also works good on carbs.
That 1200 degree engine paint does hold up pretty good, I've painted a bunch of stuff with it...it always goes on very well and seems pretty scratch resistant for spray paint.
Garrett H.
Exhaust sound clip
Another clip
Those are my MN12 7-spoke wheels after using the aforementioned Dupli-Color wheel paint (argent).
I think they turned out fantastic, but I have yet to install them on the car. I'm too cheap to put tires on them. :)
For what it's worth, this particular paint was very easy to work with. As long as I shook the can often, the metal flake didn't "pool" anywhere on the wheels; it applied very smoothly and evenly.
I used the wheel paint in gunmetal on my waffle stars, and it works very well.
They better not be Tri-bars! :D
What kind of prep work did everybody do? Or did you just clean them up a bit and started spraying?
well i did motorcycle wheels, have yet to do the wheels on ym bros car. With the bike rims i used the 3m pads, forget what they are called, but it cleaned and scuffed them up good
Quote from: Ether947;129937
Yuppers....Not going for the Cobra R look though (kind of hard to do with a Scorpio ;) )
