Topic: What are you guys using to paint wheels? (Read 6083 times) previous topic - next topic
Quote from: Chuck W;129954
Yuppers....Not going for the Cobra R look though (kind of hard to do with a Scorpio ;) )
I'm thinking about painting mine black with the tbird snowflake centers... but they are just slightly too big and it kinda annoys me. I would like to get rid of that pony though. You keeping yours?
Quote from: Ether947;130050
Nope...I'll probably just fill and smooth.
A shot on the old car...
what are they on?? and whats a scoprio?
Quote from: daboss351;130067
Quote from: Chuck W
Reading works wonders.
Anyways, for prep, i cleaned the wheels with some brake cleaner, and sprayed them. No scrubbing, no prep, nothing.
I used Duplicolor Textured Metallic on my snowflakes, and i wiped them off with a dirty rag, and sprayed them. Snow on the ground and all. Paint still looks decent.
didn't know that was the scorpio cause ive never seen one before, cause it said on the old car. And google is no help so:dunno:
Merkur Scorpio
o its a merkur, i only knew of the xr4ti i think there called. Sure is a different looking car
Well I got one done...still working on the others (cleaning, prepping, etc)
The satin black is a little more glossy than I like, but at least it's not high gloss.
That's hot. Why don't you do mine as well? :)
Uh, I don't know if you noticed, but you got some extra holes in yer wheels. :D
Quote from: Ether947;132218
;) That's because the Scorpio bolt pattern is different than the SN-95.
It looks like it will take a full can (and maybe a touch more) per wheel if you do all of it.
This paint is not as satin as I would have liked, but at least it's not full glossy.
;)If the weather holds *pleads* I'll do mine this weekend.
I'm halfway done w/ mine.  Need to get the other two prepped and sprayed.
I thought I would be slick and sneak out of here during my lunch break, but I just got a load of work dumped on my desk. This sucks, it's 70 degrees out too. :(
I love daylight savings... my fiance did the one on the left... or right. I forget.
What did you use to paint them?
I need to fill that stupid horsey on my center caps before I use them.
