Topic: Foxtbirdcougarforums Top 25 ET List! (Read 98372 times) previous topic - next topic
Reply #60
1.97 60FT
8.502@84.55 MPH  converted to  13.345 1/4 mile by http://www.fastnuf.com/QMC.html
1/8 MILE
specs
weight 3,700 est
70 429 stock bore
DOVE-C heads
A460 motorsport cam
headers,3" pipe
waterpump drive
weiand stealth intake with
750 vac secondary with the diaphram busted (no secondary action)
NOTES :sputtering of idle/loading up off the line 15 deg intial timing
Michael this was with the 429 with a few issues ,3.55 gears , ruff tune never got any better times and never sprayed it (big shot kit).
verification:
http://www.foxtbirdcougarforums.com/showthread.php?t=5000
Reply #61
Awesome! I remember when you did that. Just to clarify, I used a different 1/8 to 1/4 calculator so I could get MPH too, and I will use it on anybody with only 1/8 times (so the calculations are consistant). (TurboCoupe50, if you have some better 1/8's post them up and I'll calculate). I do need to know what tranny you had behind the 429.
Calculator here: http://www.wallaceracing.com/8th-quarter.php
Reply #62
And because I've been getting slack for no times...
Layla's Best from 2004, 100% stock with IHI and still painted 3 different colors!
Mike (ET/MPH/60) (.050)
2.231
10.499@64.70
16.487@78.14
(1st round win) (1/1)
I was HARD on the brakes to win the round of bracket racing so I'll calculate the 1/8 time. Slip to be up this afternoon.
Reply #63
Quote from: Aerobird Motorsports;128693
stock 1970 c-6 with a stock torque converter
Reply #64
And that folks, gives us 1 car in every class except 6-gun, and a Top 8 overall! WooHoo! Keep em coming!
Reply #65
Found it!
Reply #66
Excellent! You need work on that 60' time though. I expect new slips in Arpril from you :hick:
Reply #67
i have to swap in my new motor first..
393w 10.2:1 compression
351w victor jr intake
holley 4150 830 cfm carb
trick flow twisted wedge
comp cam solid roller
3.73s
T5
125 shot
and then wait for the drag strip to be opened to the public :hick:
1987 351 swap, T5, ac/smog/power steering delete, custom H pipe Borla ProXS lers..
Reply #68
This is my last full throttle pass with me driving the Gray 83 Bird. April 2006. The next pass I won the big one. First points race of the year. Points, cash and a 3 ft trophy. This is my wife's bracket racer. She let me drive it that night because my 84 lo-po Bird wasn't ready yet. THIS IS NOT THE QUICKEST PASS IN THE GRAY BIRD. (See below).It is the only timeslip I could find. It auto-shifts at 4250 rpm. LO-PO vintage 1977 460, small cam, cast iron exhaust manifolds, 600 Carter, 3.73 gears, 28 inch rears, stock 77 police car C-6. Very stock, very strong, and very consistent! I really love this car!! I have lost count of the number of wins and r/ups since April 1997.  Best et with manual shifting at 4500 rpm (it has stock 1977 rod bolts and valve spings after all) it ran a 8.60 at 82.8 mph. Car weighs 3550 with me in it. --X
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Reply #69
Thank you!
We now have a TOP 10!
Any slips on any of the other Birds there 83-88TBird Guy? :D
My LO_PO 84 Bracket/everyday Bird
Reply #70
This is my 84 Slow-Bird. It has E6 py heads, Lincoln Town Car (86-90 ?) P.O.C. engine that shifts at 4200 (because that is where it runs out of breath). It has 3.45 rear gears, stock A.O.D., Carter 600, stock 84 Mustang H.O. intake, duraspark dist. with a  GM H.E.I. ignition module, MSD Blaster 2 coil, Stock H.O. Stainless headers, H-Pipe. The car is very reliable but not as predictable to dial in and therefore has cost me several late reces. But I have learned to race (and win) as well as loose in a slow car!!    THIS TIMESLIP SHOWS WHAT HAS ONLY HAPPENED TWICE IN MY LIFE--IDENTICAL PACKAGES AND THE COMPUTER TOOK IT OUT TO THE 1/10000 OF A SECOND!!!!  The first time happened around 2000 or 2001.  Ironically, both runs were against the reigning track champion!!  This car was bought from a local charity organization with antifreeze in the oil pan for $ 280.00. One of the greatest buys for me yet. I love this car also, but not nearly as much as the Gray Bird or T. Coupe.
X
X
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Reply #71
Nice slip! That's an awfully high MPH for the ET, what's this car's best?
Taken the 83 Heritage or the 460 TC yet?
Reply #72
Birdman, the mph looks weird because the chin spoiler got the beam. (It took me years to learn that trick) I normally run 68 -69 mph with this car.  The 87 T.C. has not been to the track yet.  The 83 Heritage is waiting her turn with my wrenches. Haven't decided yet, but I'm thinking 351W for it.:D
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Reply #73
Thanks again!
I updated the MPH for the 84 to reflect a 69.00 1/8 MPH. Make sure you submit new ones when you go out again this year. ;)
Reply #74
i threw out last years time slips when i cleaned, so this is all i can find. my last post, im pretty sure i made it to the track again after this, but it may not have been the tbird i was driving...
http://www.foxtbirdcougarforums.com/showthread.php?t=9861
