Topic: Foxtbirdcougarforums Top 25 ET List! (Read 98368 times) previous topic - next topic
Reply #45
It's been awhile but here's mine... 12.23 on 225/50/16 Nitto DRs with a 85 shot of the happy juice. Best on the motor is 13.11@105.3 on 225/50/16 Michelin radials... I've never equaled that 1.900 NA 60ft... Guessing they slipped just enough to get up on the converter a bit harder...
Haven't been on a 1/4mi track lately, but it ran quicker 1/8mi times than 8.42 last spring(1/8 mi on the 13.11 run). Went 8.40 on a slower 60ft(1.93 I believe) but ran 83.xx, unfortunately I don't seem to have those slips..
Reply #46
Added! Get a new one with the 331 these season ;)
There's a black SC Cougar too, where are these guys?
Reply #47
In the 2.3 class can i submit a mustang with Turbocoupe drivetrain,or is that not cool. Let me know and I'll get a slip posted.
1999 Trailblazer(wifes rig)
Reply #48
Fox TBIRD and COUGAR forums. That would be a tow vehicle if you have a pic of it towing a trailer with a Bird/Cat on it... ;)
Reply #49
And stangs with TC guts just aren't cool period. WAAAYYY too many NICE TC's died for some rusty py notch in the last 5 years.
Reply #50
that mean im gonna get yelled at for pulling the motor from mine for a ranger?
Reply #52
but the frame rail is rotted, the trans has been taken out, and has considerable rot in the floor, other wise id be fixing it, its just to far gone, but that motor is not going in a fox stang so don't worry
Reply #53
Id say I hit a nerve there,the car I used was fn trashed.Had probably
100k miles on dirt roads,massive hail dents,paint was fading and peeling off,the pass floor was soaked from the fornicateed weather strip,pretty much coolant and water,then when I drove it home the abs didnt work,and when I held the brakes too long the wiring under the dash fried.What else did I leave out,oh I put the frontend on my car 87 t-bird,sold the rear to a guy for a cougar,engine,harness,vam,tranny,rad,electric fans,went to stang,still have doors,driveshaft,trim pieces,and rear glass.
It was like a organ donor.
Reply #54
If the car's rotted/totaled it's rotted/totaled. That's OK. It's the nice cars, the fixable cars, that bug the snot out of me.
On another note, fastcat's time is staying at #1. Since he's reusing the engine, tranny, rear end, front and rear suspension, air-ride, and othe stuff in #2 it's basically the same car only with a cage and no rust. Until #2 goes faster, #1 is #1.
BDBIRD and daboss, find me more members with slips, I can't PM them all!
That is all.
Reply #55
i got fastcat up, ill see if i can't find more. And im a 16 year old car nut, id NEVER butcher a good car, especially not a ford, maybe a import but def not a ford.
Reply #56
Weird - I didn't see this post until Michael pointed me to it :hick:
Here is my best run:
My best 60' is like 1.603 & best 1/8 MPH 90.5 MPH or so. Temp was ~50 F the night of my best slip.
My mods:
306 w/Probe pistons, 9:1 compression
AFR165 Heads
Comp Cams XE270HR-12 cam
Accel 300+ ignition
Ported/polished stock 5L lower
KB 2L blower @ 10.6 psi
March Ram Air w/9" cone, 80mm C&L MAF, 85mm Accufab TB, 4" piping
Home built H2O/Meth injection
FMS shorties, 2 1/2" dual exhaust through 18" Magnaflow lers
Tremec TKO500 tranny, 3.73's with Eaton E-Locker locking rear, 31 spl Moser axles
Tuning by TwEECer
Prolly some details I forgot, but that's the important stuff...
Reply #57
Your #2 overall, #2 in power adder, and #1 in 60's. Thank you ;) Now see if you can help me get some more people on. :D
Reply #58
I had 14.3 this past fall with a head gasket on backwards.I'll get a time slip this spring for you and see where I fit in all of this.With the new heads and all,I'll bet we can bring that down a little.By the way,all you guys,good job.
Reply #59
Injecting meth is illegal in most states. "oh you mean methanol injection,my bad". LOL!!!!!!!!!!!!!!!!!!!
