Topic: Foxtbirdcougarforums Top 25 ET List! (Read 98845 times) previous topic - next topic
Reply #166
That's Mrs TurboCoupe50... I've NEVER raced the car(on the track)...
Reply #168
soon we will have a slip from my mustang to go up on this, and posibly my stepmoms new grand prix!
Reply #169
Added in badbird's 83! #3 Overall, #3 60', #1 SB/NA!!!
Am I too late?
Reply #171
Sorry guys, Im a bit slow to join in here. I dug up my old slip of 12.11
Heres an old pic from that run...
Mods at the time of the run were:
306ci, Windsor Jr heads, Comp cams NX264 cam, 24lb'ers, Explorer intake, 125 wet shot, AOD lockup converter, 3.73's, Nitto Drag radials, and a not so great tune.
1988 Tbird Stock bottom end 306, Windsor Jr's, Explorer intake, 125 shot.
Best ET: 12.11 Best MPH: 113.8 1/4 mile
Reply #172
Added! Check out the stats:
It takes a 12.10 to get into the Top 5, a 13.03 to get into the Top 10, a 13.83 for the Top 15, a 14.39 for the Top 20, and a 15.52 to make it in the 25 at all!
10's - 1
11's - 3
12's - 5
13's - 6
14's - 6
15's - 4
It takes a 1.82 60' for the Top 10 there!
Reply #173
Chrome302jr, great run
how did the nx264 cam run without the juice?
Was thinking of that cam for speed density also.
 Thanks,
 Mike
Reply #174
Depressing, down to #15.
Reply #175
Quote from: t.birdsc;163163
 Thanks,
 Mike
The cam runs okay while not on the spray. Its been a few yrs back, but the reason I bought the cam was because of the wide lobe separation angle, I believe its 116. At the time I was running speed density, so I needed the wide LSA to give me vacuum. However, with 24lb injectors, the tune was too rich at idle and too lean at WOT with SD. I switched to a 75mm ProM MAF and the tune was much better. I tried to hold off switching to MAF as long as possible, but in the end lost. :D
If you plan to run the NX264HR cam with 19lb injectors on SD, I believe you will be okay. But dont plan to run 24lb injectors. Depending on what you setup is, 19lb injectors should be fine anyway. I think I could get away with running 19lb injectors, I've thought about switching back.
Reply #176
Thanks for the heads up on the cam. If speed density stays or goes it seems like it's good all around. Great info you have there.
 Mike
Reply #177
new best for the cougar
15.03@93 using the converter
Reply #178
did you bring your pillow to the tree? LOL!
or do you leave like most people on green?
1979 Ford Fairmont
[/B]
Reply #179
That bumped you up a little! EEK! I'm 2 spots from elimination :( Good thing I'm going this Friday ;)
