Topic: pedestal or stud (Read 2083 times) previous topic - next topic
pedestal or stud
i want to purchase a set of 1.7 roller rockers but i need to know if my heads heads are for stud or pedestal type rockers?
pedestal or stud
Stock is pedestal mount.
pedestal or stud
And mine would be too?
pedestal or stud
They all are.
pedestal or stud
my engine is stud mount
7/16 studs with an adjustment nut with an allen set screw in each nut.
aftermarkets toss the pedestal and fulcrum
if need be, drill a hole into the pedistal stand off and thread it.  OR, install a stud.
they insert a pin all the way thru the pedestal and the new stud horizonally to lock it in.
pedestal or stud
Is that one of them newfangled electric balance shafts in the lifter valley?
pedestal or stud
Quote from: JeremyB;124205
It lights up too so you can see if the engine is timed right:hick:
pedestal or stud
Scott, what heads are those?
pedestal or stud
ok thanks, what about GT-40p head? are they stud or pedestal?
pedestal or stud
Quote from: quicksilver;124312
Quote from: Tbird232ci;124186
They all are.
pedestal or stud
Quote from: jeremyb
:beatyoass: :D
Quote from: Paul Flockhart;124263
1966 / 289 heads worked over and milled to HP289 specs but with larger valves.
factory was 54.5cc but with larger than HP289 valves and milling included., it makes them have better numbers.
pedestal or stud
haha i didnt know ALL heads are pedestal, thanks for clearing that up.
pedestal or stud
Scott those studs are actually 3/8
pedestal or stud
I've heard some of the pre-1977 castings were in fact stud mount.  Can anyone confirm either way?
 Yes shawn I saw your post:hick: however I'm not sure if you meant ALL or just 5.0's from 85 is on up....
pedestal or stud
Quote from: quicksilver;124350
no, not true.,, not all heads are pedestal.
