headlights not working... December 03, 2006, 01:08:06 PM Well guys, just as the title states, my headlights are not functional. All the bulbs are new, and the wiring seems to be in good shape. This is where it gets complicated though, when I pull the blinker lever forward for my high beams the lights come on then go back out when you release the lever. The headlight switch is fine however, being that it worked in my '87 cougar. Any ideas or thoughts are valued to me. Thanks! Quote Selected
headlights not working... Reply #1 – December 03, 2006, 03:41:39 PM i had the same problem before and my headlight switch was bad, Quote Selected
headlights not working... Reply #2 – December 03, 2006, 04:30:12 PM Headlight switch is bad.The "flash to pass" switch on the stalk, is a seperate circuit that bypasses the headlight switch. It will even work with the headlight switch off. Quote Selected
headlights not working... Reply #3 – December 03, 2006, 05:41:05 PM Quote from: softtouch;116830Headlight switch is bad.The "flash to pass" switch on the stalk, is a seperate circuit that bypasses the headlight switch. It will even work with the headlight switch off.Well, that means my wiring must be bad, or there's a ground issue.I have checked the grounds on the core support and they look fine, so maybe there's a bad ground somwhere else. I wonder if there is any other electrical components that would cause this problem. also, It wouldn't hurt to try another switch. Quote Selected
headlights not working... Reply #4 – December 03, 2006, 11:15:38 PM ill bet on the multi function switchwould you happen to have any special features such as auto headlamp dimmer ect? Quote Selected
headlights not working... Reply #5 – December 03, 2006, 11:38:01 PM Yeah, jcassidy is right, it can be the multifunction switch.If you have 12v on the red with yellow stripe wire at the M/F switch, then it's the M/F switch. If not it's back to the H/L switch. Quote Selected
headlights not working... Reply #6 – December 04, 2006, 12:07:37 AM just curious if he has a auto dimmer feature. An old 78 cougar of mine had it up in the grille and went bad. Its just a photodiode but still, it prevented my lights from coming on. Now that i think about it,, that wiring was a little rigged up to say the least. Quote Selected
headlights not working... Reply #7 – December 04, 2006, 08:45:31 AM Quoteill bet on the multi function switchProbably the dimmer switch "contact bar" melted the plastic carrier and isn't making contact anymore. I just pulled the plug and jumpered the red/yellow and red/black together. Only have low beams now, and flash-to-pass highs. I'll put in my "new" switch (and relays) someday.My previous post (several pages in...)http://www.foxtbirdcougarforums.com/showthread.php?t=6454 Quote Selected
headlights not working... Reply #8 – December 04, 2006, 10:42:26 AM My tbird does have the auto dimmer function! I removed the little box on my mirror a wile ago though, so I kinda forgot about it.I'll have to ckeck out the switch to see if thats the problem...thanks guys for the idea! Quote Selected
headlights not working... Reply #9 – December 04, 2006, 10:51:16 AM Quote from: jcassity;116884ill bet on the multi function switchwould you happen to have any special features such as auto headlamp dimmer ect?hey, what manual is that? I don't recall my haynes or chilton's manual having that section... Quote Selected
headlights not working... Reply #10 – December 04, 2006, 12:27:19 PM the 87 evtm whch is about 3/4'' thick as well as the 87 shop manuals which all add up to about 7'' thick.btw,, see diagram below, you might find something interesting there. Id rewind a little and check fuses next. Quote Selected
headlights not working... Reply #11 – December 05, 2006, 06:43:26 PM Quote from: jcassity;116928the 87 evtm whch is about 3/4'' thick as well as the 87 shop manuals which all add up to about 7'' thick.btw,, see diagram below, you might find something interesting there. Id rewind a little and check fuses next.Cool... this diagram shall be quite handy in solving this problem. Thanks! Quote Selected
headlights not working... Reply #12 – December 05, 2006, 08:24:07 PM have you checked the relay? I remember messing around with the relays under my dash and my headlights wouldnt work, I put everything back the way it was and all was well. Quote Selected
headlights not working... Reply #13 – December 06, 2006, 11:54:04 AM Quote from: 88turbo;117114have you checked the relay? I remember messing around with the relays under my dash and my headlights wouldnt work, I put everything back the way it was and all was well.where would these be located? Are you refering to the ones on the branch that would be closest to your right knee wile driving? Quote Selected
headlights not working... Reply #14 – December 06, 2006, 09:55:41 PM the interior lights have a relay. Quote Selected
