Topic: headlights not working... (Read 5710 times) previous topic - next topic
the headlights on mine were affected by the relay I switched...  I dont know how.  but isnt it true that the auto lights since they are on a timer would have a relay?
Edit: What are these??
Quote from: 87tbirdmanjwg;117224
where would these be located? Are you refering to the ones on the branch that would be closest to your right knee wile driving?
yes..
you just put the dash in right? i would double check if the plugs are plugged in al the way. i had a similar pro with the turbostang and it turned out to be a plug not seated all the way. also i have a bypass plug for the auto lamps that you can have whaen i see ya next, might be a problem in the harness itself
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Quote from: 88turbo;117335
Autolamp relays 1&2 provide an alternate path to turn on the headlights (1) and the parking/tail lights (2). The main light switch would still work with these relays out.
Can't tell what the headlamp dimmer relay does. You have to go to page 84? (Blurry) and see how it interacts with the mulitfunction switch on page 77.
