Topic: Strange Question... (Read 4078 times) previous topic - next topic
Strange Question...
Ok, this may be the first time this has been discussed here.
I have a leather shift  from a '95 Camaro Z-28. It's about the same size and shape of a baseball, and it looks awesome in the car. I'll attach a picture of it.
The thing is that it's too large for my shifter. I think the Camaro shift  has a thread size of 16mm x 1.5, so it just sits loose on the shifter. I tried working some plastic aquarium tubing over the threads, then cranking down the  over it. That worked for about three days, then it worked itself loose.  :wtf:
I've been brainstorming on how I can get this thing to stay solid on there, but I'm out of ideas. I hate having a loose shift .
I wouldn't be so intent on this if it didn't look awesome inside the car.
I had one thought tonight... What if I poured some JB Weld in there, then drilled out the center and tapped it for the right threads? :welder:
Strange Question...
I wonder if you could get a Heli coil that has the inside threads that match the shifter but outside threads that match the ball?
How 'bout taking the shifter out of the car, putting some JB weld inside the ball (and on the shifter threads), and putting the shifter into the ball (but leaving it upside down so the JB weld doesn't run out) until it hardens? You could even put some saran wrap or pipe teflon on the threads of the shifter so it wouldn't glue itself to the JB Weld threads, that way you could remove it if you ever wanted...
Strange Question...
I was gonna suggest the helicoil too.  That would allow you to remove it when you want, too, down the road.
1987 TC
Strange Question...
j.b weld and rethread
Strange Question...
helicoil all the way, had a B&M shifter years ago on a car and it had a helicoil in it to fit the car it was on.
Scott
Strange Question...
I say use the JB weld or something like it. The best way I know of to keep it from sticking to the threads would be to coat it with silcone oil/lube. That is if you use the JB weld stuff to form it to the threads. Not drilling and retapping the .
Strange Question...
They used to make thread adapters for the hurst T handles that would just screw into the shift .
Strange Question...
Thanks for the replies, folks. I had thought about cutting the thread sizes on the inside and outside of a piece of pipe, but I thought it would be way too inaccurate. I guess that's what the helicoil does...
Where could I find a helicoil for these specific thread sizes?
Strange Question...
well my thought is to go to a machine shop to make a insert for that camaro shift ... possibly drill out the  a lil bit to make room for the insert that has the same threads as the shifter handle... would have to secure the insert in the  by use of glue or some sort.. im gonna do the same thing with an aluminum shift  i made for a ranger(splined) im gonna get a little insert made and have a set screw in it.
Strange Question...
Do it so you can remaove it if you ever need to.You may damage the leather somehow and it would be nice to be able to replace it.
Strange Question...
Since no one else said it....
Coug-maro!
Strange Question...
Lol.
Strange Question...
It makes the car go faster. It is, after all, from a Z-28.
Strange Question...
Finding a helicoil might be tough and jb weld is for rednex.  If possible find a weatherhead bushing and use thread locker, I've done this before and it turned out great theres even a hex on the top of the bushing, which would be on the bottom of the shift , to tighten it down.  I ground the hex down quite a bit for appearence sake, also by grinding it down you can get the  to face the exact direction you want it to when fully tightened.  Not that that would matter on a ball type .
2004 Impala
