Topic: Serpentine belt (Read 1586 times) previous topic - next topic
Serpentine belt
For the AC delete...along with smog
How long of a belt do I need, anybody have a Napa or Autozone part number?
i know sombody out there knows it.
just wanna run the essentials.
Thanks, Clayton
Serpentine belt
I don't have the number,but I have the same set up with the FRPP A/C eliminator,and my belt is 73.5 inches long.I'm also using a Mustang GT power steering bracket.
Serpentine belt
thanks man... but im not running an eliminator kit... i just want the short ass belt :D
Serpentine belt
Quote from: 87thunderbirdBlackJack;111697
So you using non-AC accessory brackets??? If not the belt draggs on it'self where it passes over the water pump...
There are so many variables, easiest way is to have some one hold the tentioner at mid point and wrap a string around the pulleys. Mark the point where it meets with a Sharpie and then measure the string between the marks...
Serpentine belt
I know it wouldnt work for me no matter how short of a belt i got the tensioner would make it hit itself on the water pump
Serpentine belt
Get the Mustang bracket for the steering pump,and the eliminator kit.There are some on E-bay.It'll clean up the engine compartment,and,it'll be "right".
Serpentine belt
Not sure where I got this, and it doesn't specify a length...
